Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
Last Post: Martysf
0 Solar battery charging
Last Post: drumbrake
0 Iree's jukbox joint
Last Post: rubine
0 Oil change 101 – Engine and Transmission oil change pics
Last Post: Twistedrench
0 Cartridge Conversion?
Last Post: sml1226
Last Post: sml1226
Last Post: GrimKvlt
0 5/12/18 - WILD RABBIT MOTO SHOW 3 - Cambridge, MA
0 4/29/18 - New Tradition Company swap meet - Worcester, MA
0 '03 883 Hugger Odd Clutch feel, 1st gear jumps out
Last Post: Wharfcreek
0 Anyone still use Cycle Shack duels?
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
Old 21st June 2012
wayfastf150 wayfastf150 is offline
Sportster/Buell Model: XL
Other Motorcycle Model: Suzuki GS 750
Other Motorcycle Year: 1981
wayfastf150 has disabled reputation
Default Take a peek at my plugs 1250 jetting
I have about 400 miles on my 1250 conversion. I read a good baseline would be 45 pilot, 185 main, and a shim under the needle with 2.5 turns out. When I went to install the jets, I saw the PO put a dynojet kit in so I dropped the clip one position (4th notch down I believe), did the 45 pilot with 2.5 turns out and a dynojet 186. The bike was a 1200 bored .010 over, and the PO had a 45 pilot in there with a 168 main jet (dynojet number). I do have popping when I shut the throttle, so I was going to try to turn the screw out another 1/4 turn, or go to a 48 pilot. While looking for jets I found a chart which compares dynojet numbers to keihin and mikuni. According to the chart the dynojet 186 main is equivalent to a keihin 210 which seems way too fat. Is there any truth to those numbers? Someone gave me a CV to use as parts (carb body is junk) so I can get rid of the dynojet kit.
Front plug
Rear plug
Both plugs were replaced with autolites when it was rejetted
Old 21st June 2012
looks just a tad rich to me
Old 22nd June 2012
EL in NH's Avatar
EL in NH EL in NH is offline
Sportster/Buell Model: model 48
Other Motorcycle Model: FLHS
Other Motorcycle Year: 1991
EL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to behold
Default Did you do a plug chop
I do one for slow, intermediate and high speed (WOT)
http://www.mopedarmy.com/wiki/Plug_chop
Peace
Old 22nd June 2012
I have not done my plug chops yet, I wanted to wait until I finished my break in. I have checked the plugs a few times to make sure it isn't lean.
Old 22nd June 2012
04xl1200c's Avatar
04xl1200c 04xl1200c is offline
Other Motorcycle Model: CB750k SOHC
Other Motorcycle Year: 1977
04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future
I ran the cvp kit and I love it!
46 pilot cvp needle (0.50 shim) and a 180 main and a lighter spring a drilled diaphram
Bike runs awesome! Really smooth and burns clean.
I love my Samson Powerflow III 2-1 Exhaust Check out the video's
Dyno Run:
[URL="http://youtu.be/q59aSkpxFbE"]http://youtu.be/q59aSkpxFbE[/URL]
After install:
[URL="http://youtu.be/f3vMKoFHw-8"]http://youtu.be/f3vMKoFHw-8[/URL]
Facebook XL Group:
[URL="http://www.facebook.com/groups/202086829894902/?ref=ts&fref=ts"]http://www.facebook.com/groups/202086829894902/?ref=ts&fref=ts[/URL]
Facebook TC88A Group:
[URL="https://www.facebook.com/groups/TC88A/"]https://www.facebook.com/groups/TC88A/[/URL]
[IMG]http://i1088.photobucket.com/albums/i334/cbsevenfiftyk/2-1%20exhaust/th_DSCN0231.jpg[/IMG]
Old 22nd June 2012
This is the chart I was looking at, does it look accurate? http://www.jetsrus.com/FAQs/FAQ_miku...ihin_sizes.htm If it is, looks like Im 9 or 10 jets too fat. Ive read the stickys on carb tuning and reading plugs, and did a lot of searches on here from what Im seeing I should be around a 45/48 pilot and 185/190 main. The bike has screaming eagle slip-ons with no cross over, stock filter, and if I remember correctly N4 cams.
Old 22nd June 2012
Lone Rider's Avatar
Sportster/Buell Model: 1200
???? the porcelain looks white to me, I thought white meant lean, no?
Old 22nd June 2012
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
milmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond repute
They look ok to me. notice the light black shading around the base below the threads.Thats where the jetting really shows. And why Dan said maybe a tad rich. But without individual plug chops lik EL stated, you wouldnt know which circuit to change.
Cant see in the pics how far up the strap the heat band goes. That is the point on the electrode strap where it changes color from heat. Should be about halfway up the strap. This is JMO and how I do mine...
Old 22nd June 2012
Do you guys think I will be alright to do plug chops with 400 miles on the top end? If I understand it correctly when doing the mains you just have to hold it wide open clutch in and hit the kill switch, you dont have to have it rev to full throttle revs correct?
Old 22nd June 2012
Bulpitt's Avatar
Bulpitt Bulpitt is offline
Sportster/Buell Model: XLH HAMMER 1250
Bulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud ofBulpitt has much to be proud of
Sorry no answers for you but there is GREAT info here so I need to subscribe...
Thanks guys!
