0 3/8 24 Banjo bolt on V rod 11/16 master cylinder
Last Post: Grumpy-Biker
0 Salutations y'all
Last Post: Alias Bob
0 no rear brake light
0 67 Sportster build
Last Post: ldurmon
Last Post: geoff
Last Post: goblin_dust
0 What's your helmet?
0 Power Vision Problems after 1275 Install
0 Sold my Shovelhead and bought an 883!
Last Post: lucky23
1Scooter (68), wallylach (67), cob (64), decman (62), djhannu (56), Vaughn, irishhog (49), dangjalopy (45), earthoverdrive (40), edman87k5 (39), 79iron (36), mr_anti_chrome
Old 22nd June 2012
bentrod bentrod is offline
Sportster/Buell Model: sportster xlh
Sportster/Buell Year: 1969
bentrod is just really nicebentrod is just really nicebentrod is just really nicebentrod is just really nicebentrod is just really nicebentrod is just really nicebentrod is just really nicebentrod is just really nicebentrod is just really nicebentrod is just really nicebentrod is just really nice
Default Made a seat, then messed it up
So I decided to make a seat starting by cutting up the seat pan from one of the seats I disliked:
Used copper pipe fittings for mockup:
Cut and shaped the foam:
Glued the vinal on then started pop riveting. When I came around the last corner I cut the darn vinal too short. From that point I was unable to make nice corners. Chances of taking off the vinal without destroying the foam is nill.:
Doesn't look too bad from a distance, what a bummer
Art
Old 22nd June 2012
416rigby's Avatar
416rigby 416rigby is offline
Sportster/Buell Model: XLCH "correct for era" HA
Sportster/Buell Year: '62
Other Motorcycle Model: G80 matchless
Other Motorcycle Year: 60
416rigby will become famous soon enough416rigby will become famous soon enough416rigby will become famous soon enough416rigby will become famous soon enough416rigby will become famous soon enough416rigby will become famous soon enough416rigby will become famous soon enough
Default Down the tubes?
Didja put springs down the frame tubes?
Old 22nd June 2012
Yeah, there's springs in the tubes, I just need some with more compression.
Art
Old 22nd June 2012
Mosey Mosey is offline
Other Motorcycle Model: FX
Other Motorcycle Year: 1976
Mosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond repute
That looks waaay better than my first attempt. It can take a couple tries to learn a new skill. Keep on keepin' on...
When yer going around corners and the vinyl wants to bunch up and fold over, you can trap the folded triangular part under a pop rivet so it doesn't hang down. I usually cut out the excess inside the fold so it's only two layers of vinyl instead of three layers. I hope you can follow my description.
A little more shaping and rounding of the foam at the nose of the seat would make it look sleeker.
I got Chevy valve springs for free at an auto repair shop that work pretty damned well and would fit in those sockets perfectly.
Old 1st July 2012
Default Second try making a seat
I think its looking better, I wanted to hide the seat mounts on the frame so I came up with this. Still have to get better tucking the material around the corners. I'm going to try another one.
Art
Old 1st July 2012
FearlessFrisbee's Avatar
FearlessFrisbee FearlessFrisbee is offline
Sportster/Buell Year: 1957
Other Motorcycle Model: Indian Scout 741
Other Motorcycle Year: 1941
FearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really nice
Hti the corners witha hair dryer or heat gun and some of the wrinkles will come out. Be careful tho! I do this with all my seats, both car and bikes. Great job regardless. Is this your first time doing a seat?
Old 1st July 2012
Robicycle's Avatar
Robicycle Robicycle is offline
Robicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of light
Doesn't look too bad though.
If you are like me though it will drive you nuts until it is perfect to you
Old 1st July 2012
I'll give the heat gun a try, this is actually my third try at making a seat.
Art
Old 1st July 2012
Art
Man, pretty dang good for a third time! Upholstery is not an easy thing to do. There is a reason most folks buy theirs. It’s more work to do it yourself but great satisfaction when you’re done, and it’s your way too!
Old 2nd July 2012
kd460's Avatar
kd460 kd460 is offline
Sportster/Buell Model: XLH883
Sportster/Buell Year: 1987
kd460 has disabled reputation
Looks good! Would like to see a pic of the pivot bracket if you could post it.
Also, for those interested in using leather, a good cheap source for leather is the thrift store or resale shops! Get an old leather jacket for cheap in the color you want and cut it up! KD
"If your horse kicks me, I'll shoot the son of a bitch!"
