0 DK's Definitive Ride Report - Some of the Best Scenic Roads Out West - Tons of Photo'
Last Post: spoon
0 first harley- help!!
Last Post: Hellbent_4
Last Post: cantolina
Last Post: mac93
0 oil cooler or not?
Last Post: Jason's Sporty
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Intro from New England
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
0 Head gaskets.
5 Is anyone with an early sportster running a 38 mm Mikuni?
Last Post: sevenyears of famine
Last Post: friday
0 Fork oil capacity for 2008 XL1200R
Last Post: guitarfish
0 Pictures of Sportster Scene 1960s
0 oil pouring out on right side
Last Post: blindfredy
0 Sunday 20th May 2018: Hope Cove
0 new oil lines
Last Post: 69sscamaro
0 switched 12V
Last Post: conv90
wayneo1 wayneo1 is offline
Sportster/Buell Model: 883 XLow
wayneo1 has a spectacular aura aboutwayneo1 has a spectacular aura aboutwayneo1 has a spectacular aura aboutwayneo1 has a spectacular aura aboutwayneo1 has a spectacular aura aboutwayneo1 has a spectacular aura aboutwayneo1 has a spectacular aura aboutwayneo1 has a spectacular aura aboutwayneo1 has a spectacular aura aboutwayneo1 has a spectacular aura aboutwayneo1 has a spectacular aura about
Default 93, 89 and maybe 87 octane?
Hi All,
My motorcycle is supposed to have high test, or 93 octane.
I put 89 in it and althought the note of the exhaust has changed- it still runs like a top.
I have heard that running 87 octane is a no go, any thoughts?
Thanks
Wayne
"It is better to be seen, then viewed."
khaskins's Avatar
khaskins khaskins is offline
Sportster/Buell Model: Sportster 883L
Other Motorcycle Model: Honda CB350 Cafe Style
Other Motorcycle Year: 1970
khaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant future
Originally Posted by wayneo1 View Post
Hi All,
Thanks
Wayne
2009 883L (Not sure) 87 octane is suggested in the service manual for 2006 883L
2006 883L
AN Big Sucker Stage 1
Rejetted Carb: Slow 45, Main 175
Vance & Hines Side Shots
Flat Track bars, 4" Joker Machine Risers
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Lepera Daytona Sport or Lepera Bare Bones Solo
Black Progressive 412 12.5" shocks
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Ol' Greasy Karl of the Spirit Stalkers MC
Outlaw Name Generator
XLForum Business Card Template
BEFORE YOU CLIMB ON YOUR MOTORCYCLE, CHECK THAT THE NUT THAT CONNECTS THE HANDLEBAR TO THE SEAT IS NEITHER TOO TIGHT NOR TOO LOOSE.
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Look in your Service Manual and go with what is recommended. If the engine is pinging then go to a higher octane. Otherwise, stay with what is recommended for your bike.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
cHarley04's Avatar
cHarley04 cHarley04 is offline
Sportster/Buell Model: XL1200C/1250
Sportster/Buell Year: 04
cHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant future
Prior to 2007 (carb'd bikes) Harley recommended 87 octane for the 883 and 91+ octane for the 1200.
Starting with the EFI bikes in 07, Harley changed the recommended octane for all Sporties to 91+.
Since the compression ratio wasn't changed on the 883, it's quite likely that you can still run a lower octane, especially when the weather is cooler.
Hammer 1250-Smash Heads-560 Cams -Hurricane Flow AC -Supertrapp Supermeg -TC88A
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
I run 89 without any problems in my 2007.
ReddTigger's Avatar
HD tech will only consider 91 octane or better. Eventhough you manual may state otherwise.
To me, its cheap insurance.. Plus I get better mpg with at least 91
States I've Ridden in
71.3 hp 70.8 tq
Old 17th July 2012
Reggler Reggler is offline
Sportster/Buell Model: 883 Iron
Reggler is an unknown quantity at this point
I've been running 93 oct, it's an extra 20-25cents per fill-up then 91 octane.
I've seen what happens when you don't run the right octane way too many times in cars that I wouldn't try anything less then 91 in a newer sporty.
Old 17th July 2012
jharback's Avatar
If you think higher octane is better gasoline then you really should do a little more research. Higher octane is not "better" gas, it is "different" gas. Higher Octance gas just requires more effort to ignite. That's why it is recommended for higher compression engines. It does not pre-ignite.
It is not "better" gasoline!
Old 17th July 2012
polaris0352 polaris0352 is offline
Other Motorcycle Model: CB450
Other Motorcycle Year: 1974
polaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the roughpolaris0352 is a jewel in the rough
Precicely. And not only that, running fuel with an octane rating higher than the engine and more specifically the ignition was designed for can lead to carbon build up. Higher octane fuels burn more slowly, so if the rating is too high, combustion isn't as clean as it could be. I use 87 myself, and I only ping in really hot weather in heavy traffic if I lug the motor. I've considered mid grade, but the ping I experience is infrequent enough not to bother me.
Old 17th July 2012
I didn't say it was a better gas. I have seen 50-60 engines need valve jobs and even a few slugs replaced because people used 87 when it said to use 91+. Vw's, Ford's, Chevy's, Honda's. 4-8 cylinders. The pinging is worse for an engine then the little bit of carbon build up.
That's just my opinion based on what I have seen and cars that I have had to fix, so I won't risk it on my own motorcycle.
