0 Another use for your Iornhead engine.
Last Post: DEEP DIVER
0 i need new bars please help!!!!1
Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
0 The norse Saga's, or Pia & Tores ramblings if you like.
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
Posted On: 56 Minutes Ago
0 Tool Roll Help
Last Post: hexnut
0 HFSM issues with installing DK Customs push button on
Last Post: hexnut
0 Crusty Curmudgeon’s Sportster Dictionary
Last Post: Matt397
Last Post: sportytrace
0 Is there a damn Tachometer on a 1970??!!
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
0 Throttle Cable Install Problem
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Front brake won't bleed 1989 sportster
Last Post: decman
0 Not charging issue!
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Last Post: brianbbs67
Old 12th July 2012
egarrett's Avatar
egarrett egarrett is offline
Sportster/Buell Model: sporty
Sportster/Buell Year: 69
Sportster/Buell Model #2: Sporty
Sportster/Buell Year #2: 60
Other Motorcycle Model: Pan, Evo, Indian
Other Motorcycle Year: 61
egarrett is a jewel in the roughegarrett is a jewel in the roughegarrett is a jewel in the roughegarrett is a jewel in the roughegarrett is a jewel in the roughegarrett is a jewel in the roughegarrett is a jewel in the roughegarrett is a jewel in the roughegarrett is a jewel in the roughegarrett is a jewel in the roughegarrett is a jewel in the rough
Had a bog down problem once...The tranny fluid had leaked out and the shafts and bushings seized.
Old 12th July 2012
brucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant future
it may have been a,little hasty,to pull the motor so,soon,several check's can be made with the motor in the frame. but that's water under the bridge,now.
kizzletruck kizzletruck is offline
Sportster/Buell Year: 1971
kizzletruck will become famous soon enoughkizzletruck will become famous soon enoughkizzletruck will become famous soon enoughkizzletruck will become famous soon enoughkizzletruck will become famous soon enoughkizzletruck will become famous soon enough
Default -Update- Heads off/Pictures
Well guys, I pulled the heads off the motor and looked inside. It seems the front piston and combustion chamber has much more soot and carbon on it than the rear. I am wondering if the front needs valves/guides/seals. I also pulled the rockers off and gave the rocker arms a wiggle to see if there was any play. None noticeable.
Generator was pulled out. The gear on the gen is intact, as well as the idler gear in the cam cover. I suppose I could pull the oil pump off and inspect that. I know my buddies '70 CH had the gear in the oil pump fail and shatter into a million pieces, so I am hoping this was not the cause and that it is a simple valve job. I don't have the clamp/compressor to remove the valve springs.
Do you guys think I should pull the jugs/pistons and that? I also found that the rear motor mount is cracked and had been welded and has since cracked again.
Here is what I've got for pictures so far, so let me know what you guys think.
Front Combustion Chamber
Front piston
Rear Combustion Chamber
Rear Piston
XLFREAK XLFREAK is offline
XLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really nice
You should have done a compression check before pulling the heads. Looking at pistons is not a good way to debug motor. There are many reasons for crud buildup and some can be solved by just replacing plugs or wires. While you are this far down, run pistons to the bottom of the bores and see if there are any major scratches up and down the bores.
do not pull the oil pump at this point. i,wouldn't have pulled the motor to troubleshoot,but i,already said that.
Old 17th July 2012
Sportster/Buell Year #2: 1980
ezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to behold
Well since your being nosey.You can release the valve keepers by taking a socket about the dia.of ring and place on top and smack it with a hammer keepers should pop out.Now you will need something to reinstall keepers.Look in the red stickies at the top of this page and look for homemade tools maybe someone has something in there that'll wk.
Murphy's Law :vvet:
Old 17th July 2012
Some auto parts places [Canadian Tire is one] rent shop tools for the cost of the tool, then refund the complete rental charge when you return it. I used a valve spring compressor like this before i had my own.
In my limited experience carbon buildup is common in these engines [?because they run better on the rich side?] and is not evidence of a serious problem.
Old 17th July 2012
phideux phideux is offline
Sportster/Buell Model: ironhead
phideux is on a distinguished roadphideux is on a distinguished roadphideux is on a distinguished roadphideux is on a distinguished road
Sometimes it's the simple things, did you check or change your plugs before you pulled everything apart?? Mine would act like that if my S&S E was off just a teeny bit on the rich side and my plug would gas foul.
Old 17th July 2012
There are no major scores or scratches in the bores. Before I towed the bike home I put new plugs in it on the side of the road. No success. At this point I am at a loss of what to check. I am going to pull the points cover and see if everything is still in adjustment. (I know I could have done this with the motor in the bike, but realistically I only have 4 hours of work into the bike.. I obtained lots of practice tearing my roommate's '70 CH down when he ran into the trouble with the oil pump. He figured he mine as well have the frame blasted and coated and reworked all of the tins. Not really too worried about it since I have the entire week off of work.
But what I was thinking is maybe worse case scenario is I can have the frame blasted and coated, and do whatever motor work may need to be done. It is to my understanding that in order to replace the rear motor mount I have to split the cases. Would it be advisable to bring it over and have it re-welded again?
I can tell you that I don't think the manifold was sucking air, as the last person to work on the bike used a thin layer of RTV on the O-Rings and everything was pretty well stuck together.
I can also measure the bores and see if indeed the motor was bored out or if the guy I bought it from is full of $#!T.
Worse case scenario, I am out a few gaskets and some time..
Old 17th July 2012
Tracker's Avatar
Tracker Tracker is offline
Sportster/Buell Model: XLX-61
Sportster/Buell Year: 1983
Tracker is an unknown quantity at this point
My Super E would do the same thing when my accelerator pump was set way too rich. It would gas foul the front cylinder, lose power and back fire (after fire to some) and barely able to get off the road under it's own power. Got things adjusted and all is well.
Tracker
"If it doesn't have an engine it's not a sport, it's just a game."
