0 Sportster or Street Bob
Posted On: 40 Minutes Ago
Last Post: RKN
0 Drive Chain Adjustment
Last Post: paulc
0 Newbie CV rebuild
0 1977 xlch starter issues
Last Post: datimm09
0 no rear brake light
5 Transmission HELP!
Last Post: Twistedrench
0 Reflectors...Yeah, or Neh
Last Post: glbsportster
0 touchy feely sissy bar emotions poll
Last Post: kap
0 Primary Chain Adjustment
Last Post: sltm1
Last Post: brianbbs67
0 Tachometer drive
Last Post: sleighcrane
Old 15th July 2012
goirish64 goirish64 is offline
goirish64 is an unknown quantity at this point
Default cam thrust washers
Took the cam cover off of my 77 xlh 1000 today and noticed as i did that only one of the cams had a thrust washer on it. i looked at my clymer manual and it showed all of them having this washer. someone was in the motor before ( has s&s flywheels and connecting rods) and i was wondering if anyone would know why they wouldnt be there or if anyone has seen something like this before.
Old 15th July 2012
GA_Ironhead GA_Ironhead is offline
Sportster/Buell Year: 1962
GA_Ironhead has much to be proud ofGA_Ironhead has much to be proud ofGA_Ironhead has much to be proud ofGA_Ironhead has much to be proud ofGA_Ironhead has much to be proud ofGA_Ironhead has much to be proud ofGA_Ironhead has much to be proud ofGA_Ironhead has much to be proud ofGA_Ironhead has much to be proud ofGA_Ironhead has much to be proud ofGA_Ironhead has much to be proud of
Shims or no shims is a contentious issue. The best advice I can offer is to educate yourself and then decide if you think you need/want them.
http://xlforum.net/forums/s....php?t=1003853
Old 15th July 2012
No thrust washers, but there are cam gear plates [AKA dog bones, figure 8s] and cam shims. Presumably you mean the shims?
Old 15th July 2012
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
chevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to behold
Was it only the #2 cam w/ the points that was shimmed?
Old 15th July 2012
yeah iron mick it was the cam shims between the bushings and the actual cam. i dont know if its aftermarket camed or not, but i cant find any marking on the cams. and yeahchevelle its the rear cylinder intake cam, the one that drives the points
It could be that only the one cam needed to be shimmed. You can either toss all the shims or go thru the process and set them all up to between .015 and .020 [i think that is what we agreed on]. Most agree that the spec in the FSM should not be used.
timberjack's Avatar
timberjack timberjack is offline
Sportster/Buell Year #2: 1973
Other Motorcycle Model: 2002 sporty heavy modded
timberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura about
I set mine up right around .015 mark never herd an iron so quite,if you go tighter as the manual says it means check this every season...
chevelle's Avatar
The #2 cam gets a seal, so it would be the most important to keep from walking I would assume.
Same goes for the ign rotor/advance unit bolted to that cam.
Probably gonna toss them mick the noise doesn't bother me but I wanted to make sure it wasn't overly critical. Thanks for the continued help!
Old 17th July 2012
brucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud of
i'm,kind of surprised you went back with them at .015,timberjack.didn't you find alot of them in your oil pump,after disassembly?
