0 1974 Ironhead
0 24633-77 Breather assembly
Last Post: Fridge
0 New Member in Green Bay, Wisconsin
Last Post: GeoK
7 New Guy here, Central Coast CA
Last Post: GeoK
0 ‘68 XLCH...transmission
0 New from Utah
Last Post: GeoK
5 Metal Gaskets or RTV for top end?
Last Post: hexnut
Last Post: Jheitt
Last Post: Jheitt
5 Who wants to guess what's trying to kill me on my bike?
0 primary chain temp.
Last Post: shovithead
Last Post: cazz1000
Posted On: 56 Minutes Ago
3 Wtb, Wts, Wtt, Wtg (EFIs)
Last Post: Crash7557
  #101
Old 21st July 2012
brucstoudt brucstoudt is online now
brucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud of
battery positive terminal on the,battery ve,represent's,voltage.+,represent's,positive terminal on,battery. -,represent's,ground.
Old 21st July 2012
Sportster/Buell Year #2: 1980
ezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to behold
On your bike you can do it on the reg by touching a wire from Bat terimnal to Gen terminal
Murphy's Law :vvet:
Old 21st July 2012
mikethebike61's Avatar
mikethebike61 mikethebike61 is offline
Other Motorcycle Model: BMW K-1200/GT
mikethebike61 has much to be proud ofmikethebike61 has much to be proud ofmikethebike61 has much to be proud ofmikethebike61 has much to be proud ofmikethebike61 has much to be proud ofmikethebike61 has much to be proud ofmikethebike61 has much to be proud ofmikethebike61 has much to be proud ofmikethebike61 has much to be proud ofmikethebike61 has much to be proud ofmikethebike61 has much to be proud of
Originally Posted by xlh59 View Post
ahhh -- but that would be only the case, if there is a consumer attached to the generator, right? And the field coils would ghave to be grounded as well .... or am I wrong?
The generator had nothing attached to it ... no light, no horn, no ignition, no regulator - nothing. Without a consumer and a regulator and open field coils the generator should not produce more than 5 or 6 volts and ther would be no current, right?
mikethebike - I am trying to understand, so please correct me if I am wrong.
Was it wired to a battery?
Grind1203 Grind1203 is offline
Grind1203 is an unknown quantity at this point
Thank you. I found another broken wire. So that should fix it then I will polarize the genny. I got more problems though. My bike has stranded me due to that broken wire. It's now fixed, I got all my lights back on but now when I go to kick it it's like there is no compression. Seems ok when the bike is stone cold. I was on the way to the shop who did my top end rebuild. I have a leaky front rocker box oil line that started seeping after the first 500mi. I am about 1000 miles into my break in period. 50-55mph for the first 500 miles and 60-70mph for another 1,000 miles I have been varying the speed like the sheet says. Oh and my rear header was like half way off the spigot. I think I found my fart issues.
I would adjust my valves per video in red stickies for the cold hot tells me yours valves are to tight.loosen oil nut all the way out wiggle tube around a little reinstall nut making sure you don't cross threat it and tighten it back up.
Cool, thanks ezmerf! The bike is at the shop. Stupid kid taking me and my bike back on the trailer managed to snap the kickstand off! luckily it was the stand and not the mount on the frame.
Cool, thanks ezmerf! The bike is at the shop. Stupid kid taking me and my bike back on the trailer managed to snap the kickstand off! luckily it was the stand and not the mount on the frame. I'll make sure the Indy knows to double check those pushrods. Sorry I know this is a voltage reg thread, I really appreciate the help. I'll make a new thread when something new comes up.
You sure the kick stand broke?Most time it's the retaining pin has only worked it's way out.
Old 28th August 2015
TheWind TheWind is offline
Sportster/Buell Year: 1966
TheWind has disabled reputation
I fried my regulator when my gen shorted I guess, I am buying a Chevy 3 lead regulator today and I am not exactly sure which lead the F and A go to? Don't have it yet, but will in a couple of hours so I haven't seen the leads yet.
Also I am going to run the fuse, I do know I saw a post mentioning that, so maybe that is enough info to figure out the other 2 leads?
I ride a 66 XLCH with a mag. No battery. On my way from MI to OR already had lots of fun with coughing and popping thru the carb, all that finally took to fix was advancing the timing a little after tearing the carb apart 5 times.........lol
I know the Car Reg is not a good way to go, but it is what I can afford at this stage and I only need to make it hear from ND to OR...........yeeeeeeeeeeeeeeeeeeeeeeeha, gotta have some tail lights for those Grizzly Bears to see as I blast away from them
thanks guys, great thread, learned a hell of a lot from the good DR. !
Welcome! to the IronHead forum.
I do not know about that reg but someone should be along soon who does.
