21st May 2007
Posts: 2,346 Sportster/Buell Model: XLH Sportster/Buell Year: 1987 Sportster/Buell Model #2: XLH Sportster/Buell Year #2: 1991 Other Motorcycle Model: Sportster XLH Other Motorcycle Year: 1995
'67 engine oil puddle
Seems to be coming out the primary at the kicker shaft? How does it get from the oil tank to the primary anyway?
I've never worked on a IH before, so forgive my ignorance, please.
Sam
21st May 2007
Senior Master Bike Builder
Posts: 2,167 Sportster/Buell Model: 93 Cubic Inch XLH Sportster/Buell Year: 1975 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1968 Other Motorcycle Model: Ultra Limited Other Motorcycle Year: 2014
Dakin, are you saying the shaft is leaking from the seal were it comes out of the case on the right side of the engine?
21st May 2007
Posts: 2,463 Sportster/Buell Model: XLCH Sportster/Buell Year: 1972 Other Motorcycle Model: Heritage Softail Other Motorcycle Year: 1999
My '72 has leaked there forever. Tried all kinds of things, new bushings ,various o-rings, etc. and it still drips. I wonder if its casting porosity. Anyway the oil that's dripping is from your primary/trans not from your oil tank. The primary is a separate inventory of oil from your engine. There is some potential for oil transfer between engine and primary but if every thing is in good shape there should be vitrually none.
21st May 2007
Posts: 243 Sportster/Buell Model: xlh Sportster/Buell Year: 1975
Check your primary oil level. Might be too high.
21st May 2007
The oil goes in the oil tank and out on the ground. The trail comes from the primary in the vicinity of the kicker shaft. There is a check ball in the oil pump, right? Maybe it's leaking past there, into the crankcase and the crank bearing into the primary?
Cut to the chase; I don't want to pull the motor and find a welding job.
Sam
22nd May 2007
Posts: 5,432 Sportster/Buell Model: XLH Sportster/Buell Year: 72
trying to find out if you mean the primary oil or the engine oil.
could be a loose/damaged hose,cracked tank.primary oil is not involved with engine oil.
22nd May 2007
What year bike are we talking about?
22nd May 2007
Sam,
Your oil tank may be leaking. Only way I know to check is to pull it and leak check. Engine oil goes from the tank to the pump. When the engine starts it unseats the ball check and oil flows thru the engine. If the ball check is leaking by it will collect in the cases and puke out the crankcase vent when you start. A leaking ball check won't give you the symptoms you see.
30th July 2012
An old thread, but the same bike is back.
The constant drip was solved last year.
The "one-way" valve in the primary was stuck open.
Fixed with a self-tapping screw and a dab of JB weld.
Sam
Thread Tools |
Display Modes |
