0 strange small wires attached to coil
0 24633-77 Breather assembly
Last Post: ericfreeman
5 Transmission HELP!
Last Post: Twistedrench
0 Everyone Should Read This ... (correct assembly and break-in)
0 Sportster or Street Bob
Last Post: Baby883
0 Ei
0 New Front Rotor and Pads - Which Ones?
0 Solar battery charging
Last Post: wachuko
0 primary chain temp.
0 2016 48 Hesitating
Last Post: XLXR
0 New Member in Green Bay, Wisconsin
Last Post: prahxy
3 14th APRIL 2018 - THE BIG ONE TAKE 3 - SPORTSTER SICKNESS U.K.
Last Post: hhugger
Old 30th July 2012
IronMonster's Avatar
IronMonster IronMonster is offline
Sportster/Buell Model #2: 1988 1200C
IronMonster is an unknown quantity at this point
My 09 Nighty Bottomed out all the time. I even replaced the shocks with Road King air rides...no dice. I know he definately will bottom out, its not him, its the bike. I have had 6 harleys, all sporty's and the Nighty was the only one that did that. I scarped my kickstand almost every ride effortlessly!
"Be real...live a life worth dying for."
Old 30th July 2012
frank b frank b is offline
frank b has a spectacular aura aboutfrank b has a spectacular aura aboutfrank b has a spectacular aura aboutfrank b has a spectacular aura aboutfrank b has a spectacular aura aboutfrank b has a spectacular aura aboutfrank b has a spectacular aura aboutfrank b has a spectacular aura aboutfrank b has a spectacular aura aboutfrank b has a spectacular aura about
Mine was hard to ride too, and I'm no rookie. The bike just isn't set up for carving corners. But since I removed the "curb feelers" from the pegs, put on 1 inch longer rear shocks, and Progressive fork springs, and changed the pipes, I haven't scraped anything.
Old 30th July 2012
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
The bike is definitely not designed to be a knee scraper... so if he is riding it like a sport bike then he for sure will scrape stuff.
That's a low scoot. It's going to scrape.
Old 30th July 2012
1250IRON's Avatar
1250IRON 1250IRON is offline
Sportster/Buell Model: Iron
1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light
Well there isn't much clearance between the ground and the frame with a person on it. anything close to that height will scrape the frame when going over it. happened a few times with my iron, but now i try not to go over any speed bumps if i can help it.
2009 Iron 1250 Kit Stage 2 Light 883 Heads 497 Cams RB LSR 2 into 1 Thundermax Ecm
Old 30th July 2012
LilWop's Avatar
LilWop LilWop is offline
LilWop has a spectacular aura aboutLilWop has a spectacular aura aboutLilWop has a spectacular aura aboutLilWop has a spectacular aura aboutLilWop has a spectacular aura aboutLilWop has a spectacular aura aboutLilWop has a spectacular aura aboutLilWop has a spectacular aura aboutLilWop has a spectacular aura about
Happens to me; all the time. Is your nephew a little husky? I changed my pegs as the feelers hit every ride - when I am riding with a little more spirit the kick stand rubs every left turn - I have even scraped my exhaust a few times (although it was the stocker). It IS a problem with this bike - if you can call it a problem - He did buy a down low "hot rod" style bike!!
Old 30th July 2012
sloth's Avatar
sloth sloth is offline
Sportster/Buell Model: XL1200 sporty
Sportster/Buell Year: 91
Other Motorcycle Model: super glide
Other Motorcycle Year: 01
sloth has a spectacular aura aboutsloth has a spectacular aura aboutsloth has a spectacular aura aboutsloth has a spectacular aura aboutsloth has a spectacular aura aboutsloth has a spectacular aura aboutsloth has a spectacular aura aboutsloth has a spectacular aura about
Originally Posted by Monkey55 View Post
He needs to take the safety course before he gets seriously hurt or hurts someone else.
A Sportster is not a beginner's bike.
E
He did the safety course. When i heard he got it i was a bit surprised. Iam afraid he,s going to hurt himself but like i said before i think he might be a little gun shy now.
I,ll mention the shock adjustment to him also. See if it helps. Thanks again folks. I,ll report back at a later date.
Old 31st July 2012
1250IRON's Avatar
Not much of a lean angle on these bikes before scrape....scrape. nature of a low cruiser.
Old 31st July 2012
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: FLHP
Sportster/Buell Year #2: 2016
Other Motorcycle Model: 13 Guzzi V7 / 11 Duc 696
It's a low bike.
FOR THE RECORD - What scrapes is going to vary with pre-load adjustment/rider weight and road conditions (flat, on-camber or off-camber).
Generally speaking if the preload is set firm enough he MAY scrape the pegs or feelers, but on midmount bikes he can also scrape the hard mount itself.
You may also scrape the kickstand bracket on lefts and, as you noticed, you may also scrape the muffler mounting bolts on the right side.
Personally our 1200L scraped just too damn often and limited cornering too much for my tastes and we eventually raised both the front and rear.
Old 31st July 2012
d_eggman2's Avatar
d_eggman2 d_eggman2 is offline
Other Motorcycle Model: 96 Honda 300 4TRX
d_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to beholdd_eggman2 is a splendid one to behold
Put some RK air shocks on the rear, it raised mine a inch or so.
Forgive your enemies, but never forget their names.
John F. Kennedy
When I was old enough to ride a motorcycle and got my license, I bought a '69 Sportster.
Chuck Zito
A man who carries a cat by the tail learns something he can learn in no other way.
Mark Twain
Old 31st July 2012
oldghost69's Avatar
oldghost69 oldghost69 is offline
Sportster/Buell Model: XL883L
Other Motorcycle Model: FXDC
Other Motorcycle Year: 2009
oldghost69 is a glorious beacon of lightoldghost69 is a glorious beacon of lightoldghost69 is a glorious beacon of lightoldghost69 is a glorious beacon of lightoldghost69 is a glorious beacon of lightoldghost69 is a glorious beacon of lightoldghost69 is a glorious beacon of lightoldghost69 is a glorious beacon of lightoldghost69 is a glorious beacon of lightoldghost69 is a glorious beacon of lightoldghost69 is a glorious beacon of light
E
+1. And yes, a Sportster is not a beginner's bike indeed.
