Last Post: Martysf
0 Solar battery charging
Last Post: drumbrake
0 Iree's jukbox joint
Last Post: rubine
0 Oil change 101 – Engine and Transmission oil change pics
Last Post: Twistedrench
0 Cartridge Conversion?
Last Post: sml1226
Last Post: sml1226
Last Post: GrimKvlt
0 5/12/18 - WILD RABBIT MOTO SHOW 3 - Cambridge, MA
0 4/29/18 - New Tradition Company swap meet - Worcester, MA
0 '03 883 Hugger Odd Clutch feel, 1st gear jumps out
Last Post: Wharfcreek
0 Anyone still use Cycle Shack duels?
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
  #41
Old 17th August 2012
jhaines's Avatar
jhaines jhaines is offline
jhaines is an unknown quantity at this point
Plan b. from the same guy that trailers me home when I break down. It's good to know people. Present company included.
I'm just a newb with an ironhead, a toolbox, a computer and a FSM.
Old 18th August 2012
I was not impressed with the Pine Sol, altho i did not boil it. IMO you need something more corrosive for a gunk'd up carb. Maybe that is why it is called Gunk. Wish i could find that stuff around here.
brucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud of
gunk is good! [with 3,quart's,you shouldn't have to add any water!]
nikki's Avatar
nikki nikki is offline
Sportster/Buell Model: xls roadster
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
+1 on the gunk my dad used it in 1974 when we rebuilt the carb on my 63 dodge dart when I was 17 , so when I rebuild a carb I get two spray can of carb cleaner ,I spray in a 3 lb coffee can to soak the carb in , then I use the other can to spray out all passages , then I blow the carb out good with air , reassemble the carb . Nikki
berryman's is the carb cleaner i,remember,piniongear mentioning in his post.it's mentioned in the sticky's,in another member's post. under cleaning carb's.
hogmania hogmania is offline
Sportster/Buell Model #2: xlh
Sportster/Buell Year #2: 1977
hogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura about
I got the EZ adust mixture screw and filed a mark on the thumb screw part and I can easly count the turns and adjust it on the bike great, best addition to the carb.
Sportster/Buell Year #2: 1980
ezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to beholdezmerf is a splendid one to behold
I've used both Berrymans and Gunk and the gunk i got back when when I pulled carb out it looked brand new not so with berrymans but I haven't seen the gunk in the can around here figured the EPA messed that up don't know.JMHO
Murphy's Law :vvet:
jhaines's Avatar
So after soaking all night in the Gunk the carb looks brand new... But still has clogged bypass jets. Using a single strand of braided wire I can verify they are still blocked.
The challenge is that there is no way to isolate that part of the circuit to get good air pressure on the back of the clog. Even with the mixture screw in and completely seated most of the air still bypasses into the main jet.
There's a milling plug directly above the clog which would have been the perfect place for a clean out point. But I guess 35 years of hindsight is usually 20/20 right?
So anyway. It's back in the dip. Any other suggestions?
nikki's Avatar
ezmerf that is why I buy 2 spray cans of gunk , putting one in a 3 pound coffee can , to soak the carb in , the other one to spray all the passages out with . Nikki
jhaines's Avatar
Jets are clear. I know Mick wasn't a fan of poking them with wire, but I was out of options. Made this "tool" out of the smallest sewing needle I could find and a set of surgical hemostats. Worked like a charm.
