Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > DYNO Charts and Result
0 Help with my clutch please
0 C.O.B.B run west
Last Post: skien
Last Post: Bwf347
0 New 2017 H-D Street Rod XG750A
Last Post: Bone
0 Removing oil key from shaft
0 Range With EFI 3.3 Gal Tank
0 2003 1200 Custom riser
Last Post: ahusain
0 What's your helmet?
0 Poll: how many people have/will trade(d) up to a new Sportster?
Last Post: The Crusher
Last Post: ed_in_az
Old 5th September 2012
04xl1200c's Avatar
04xl1200c 04xl1200c is offline
Other Motorcycle Model: CB750k SOHC
Other Motorcycle Year: 1977
04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future04xl1200c has a brilliant future
Default 2004 XL1200C Samson powerflow III W/ dB killer baffle
Well I went to the dyno guy today he said my dB killer baffle was holding me back that if I had the more open baffle and better jets he would have no problem with my bike making 75+ Hp!
65HP & 72ft. Tq was not bad the bike pulls really strong and the AFR's where dead on the guy said I did a good job with my carb tuning. I know I didn't pull huge #'s but the bike pulls strong and smooth. I think I am done with the performance of the bike I just want it to run good. the TQ pulls really strong and it makes good HP plenty enough to get a ticket on the HWY or on a Mountain Road.
1200cc
Stock Heads
Stock Pistons
Stock Cams
CV-P kit in the carb 46/ 175 (rebuilt carb) (CVP needle "no shims") (CVP Emolsion tube) (CVP light slide spring) idle mix screw 2.5 turns
CVP V-Ducktor Kit
SE A/C with K&N E-3040 filter (3/4 taller "more air flow")
TC88A Ignition (Rico's R&D map- Nomad)
Champ 1 step colder plugs 10R6?
8mm Accell Spiral Core Wires
Stock Coil
Samson Powerflow III 2-1 exhaust (PN: C2-331) w/dB Killer Baffle (PN: A-171 1in 5/8 baffle) standard baffle is normally 2in and a MUCH more Open design.
30T front pulley (HDI gearing)
New CPK
New Intake seals
Extra plate kit clutch (Alto) (9plate)
Oil Cooler (HD)
20W-50W mobile 1 V-Twin Oil
FXR WIX filter 1214?
Amsoil 20W-50W Tranny Oil.
Oil temps on the dyno where 205F-235F
Dyno Results 65HP 72ft. TQ not bad
Here is Billy hooking up the O2 Sensors
I installed the CVP V-Ductor we will see if it helps or if it is a Gimic but so far is seems to have improved the MPG a few... time will tell
PN A-171 1in 5/8 dB Killer baffle
I love my Samson Powerflow III 2-1 Exhaust Check out the video's
Dyno Run:
[URL="http://youtu.be/q59aSkpxFbE"]http://youtu.be/q59aSkpxFbE[/URL]
After install:
[URL="http://youtu.be/f3vMKoFHw-8"]http://youtu.be/f3vMKoFHw-8[/URL]
Facebook XL Group:
[URL="http://www.facebook.com/groups/202086829894902/?ref=ts&fref=ts"]http://www.facebook.com/groups/202086829894902/?ref=ts&fref=ts[/URL]
Facebook TC88A Group:
[URL="https://www.facebook.com/groups/TC88A/"]https://www.facebook.com/groups/TC88A/[/URL]
[IMG]http://i1088.photobucket.com/albums/i334/cbsevenfiftyk/2-1%20exhaust/th_DSCN0231.jpg[/IMG]
04xl1200c's Avatar
here is one of the 3rd, 4th, & 5th gear pulls he did to check the AFR..
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
Sounds great!
"Only Fools Celebrate A Fool"
04xl1200c's Avatar
Originally Posted by ~Grind~ View Post
Sounds great!
More importantly it runs awesome! The guy was very supprised how close the jetting was :-D Rocketman is awesome he sure knows his CV jetting and the "CVP" jet kit helped a lot as well!
So whatcha got? Jetting? Breather? We know about the pipe.... ahhhh TC88A with which map? Cams?
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
nice pull good job looks like a fun bike to ride.
04xl1200c's Avatar
Ok i Edited the post to show what I have...
04xl1200c's Avatar
so i put Shell 91OCT gas (FULL TANK) and i road about 38miles or so both ways to the DYNO shop and he did WOT pulls on the bike as you can see in the YT video (about 9 of them)
So i filled up with gas and i got 41mpg (my speedo is a few mph off) but still b4 i fixed the carb i was getting a consistant 36mpg or worse... so even with the DYNO pulls i got 41MPG i thought that was pretty good!
wilkin4's Avatar
wilkin4 wilkin4 is offline
Sportster/Buell Model: XL1200 S/ sold
Other Motorcycle Model: Suzuki M109R/ totaled
Other Motorcycle Year: 2008
wilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond repute
I like the CVP jet kits.
I was running lean and upped my low and main jet, and my mileage improved even with me running the crap out of it.
On the Highway to Hell, no stop signs, no speed limits.......
Old 6th September 2012
rocketmangb's Avatar
I think the baffle is leaving some ponies on the table
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Mikuni HSR 45 /Hammer Billet Manifold
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
