Last Post: SLW210
0 New from Michigan
0 D&D Bobcat Fitment Question
0 T bars or Apehangers???
Last Post: D-RAIL
0 05 carb rebuild no start
Last Post: Legion Prime
0 73 XLH For Sale, what's it worth
0 Another Ohio Meet & Eat?
0 Nothing to See/Hear
0 Boring intro
0 Howdy From Texas
Last Post: FiftySixer
0 Help Identifying Pistons
Last Post: Staffords
0 Chinese S&S carbs
0 1275 Kit and Krome Werks Headers?
Last Post: wrkdWS6
0 Replacement oil pump year 74
Last Post: Virto
0 CV carb running way rich!
Last Post: oldboy
0 Hard Starting - Engine Warm/Hot - Bendix/Zenith Carb
0 Riding pants repair?
Jacquesnuenen (73), ocndaf (63), Wild Child (51), jetdoc1971 (49), Jmoses71 (49), Naugahyde (46), binksy (43), disasterousmark, KOOOPSD (35)
Chewbaca's Avatar
Chewbaca Chewbaca is offline
Sportster/Buell Year: 1973
Chewbaca is an unknown quantity at this point
Default Top end reassembly...what goes where!?!?!
So I am installing new top end gaskets to my 72 XLCH. Problem is when I took everything apart, i didn't label what was front or back.
The heads are painted and I can't identify which is front or rear, although I think the exhaust and intake ports can help me figure out which is which. The intake port has a thinner lip as opposed to exhaust port that has the wider lip for the pipes to slide over. Correct?
The rocker boxes however, have a number 1 and 2 stamped on them. Can someone explain which is front and which is rear? I don't want to put them in backwards!
Thanks!
NLXL's Avatar
NLXL NLXL is online now
The intake valves are the largest valves. When you install the heads these should face each other.
Sportsterpedia
NLXL's Avatar
Look at the oil feed lines to determine F & R rocker box.
Make sure pistons have valve relief on the intake side.
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
Next time take pictures and label parts.
kitabel kitabel is offline
Sportster/Buell Year: 1989
kitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to beholdkitabel is a splendid one to behold
Spark plugs are on the left
doodah man's Avatar
Not only do the intake ports have the thinner lip you mentioned, but before you crank the proper 65ftlbs of torque (in three increasing increments) make sure your intake manifold is properly lined up - the intake doesn’t actually touch the heads in the correct position, it will have an equal gap all the way around between both ports at the same time; it’s the intake o-ring’s job to fill in the gaps - then torque the head bolts. And make sure the head gaskets match the two oil drain holes in each cylinder!
Tim The Grim's Avatar
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 96
Also, if your motor is in the frame, I think you want to have your rear rocker box in place, with gaskets and bolts, before you place the rear head on the cylinder. It doesn’t have to be tight but at least in position.
Once the head is on, there’s no room to get the rocker box in there between the frame tube and the valve springs.
'54 KHK (Current Build) '76 XLCH (sold), '13 XL Seventy Two, '97 Honda Valkyrie. I’m Retired 🥃
doodah man's Avatar
+1. Good point! In fact, leaving the rocker box loose helps you to get down onto the head bolts.
