Stairman, toby61, Greywolf (73), federico (70), Big D (69), robin82732 (58), jbd777 (52), Steve3888 (50), RIORoosen (48), NXC1978 (44), JeffsJeep04 (37), Matt.loup.t |
24th June 2016
Posts: 48 Sportster/Buell Model: XLCH Sportster/Buell Year: 1974 Other Motorcycle Model: Kawasaki KZ 750 LTD Other Motorcycle Year: 1982
Cleaning clutch parts
Ok so the primary chain adjuster got some grooves in it from being too tight, there were some bits at the bottom of the primary cover and here and there, what can I use on the clutch pack to clean it, I know some solvents are probably bad to use on the discs, these are new with maybe 20 miles on them.
24th June 2016
It is not uncommon to have grooves in the adjuster. Is the teflon pad what is grooved? Lots of Sportster run with just the metal and no teflon at all. That is the reason running 60 wt oil works so well in these engines. "Bits and Pieces" ? Metal or plastic? Is the clutch a stock dry clutch or wet plates?
24th June 2016
Post no Avatars!
Posts: 4,119 Sportster/Buell Model: 1200S Sportster/Buell Year: 2001 Sportster/Buell Model #2: XLH-883D Sportster/Buell Year #2: 1988 Other Motorcycle Model: FXDXT Other Motorcycle Year: 2001
Brake parts cleaner works on clutch discs.
