0 Chinese S&S carbs
0 41mm V-Twin Narrow-glide conversion for XL
8 Inexplicable miss
0 New Guy with Experienced Bike
0 Bandanas
0 Top end failure
Last Post: Mission1
0 XR mutt race bike progress
Last Post: Scott
5 Eye Protection When Riding?
0 Ignition advice
Last Post: Rhode Warrior
0 1992 XL ignition explained
Last Post: Bwf347
0 Proven external Fuel pump and regulator
0 New guy from IL
0 normal shifter shaft wobble
0 Front Brake Upgrade
Last Post: keithnh
0 Info needed on mini sumps.
Last Post: Randy_rots
0 Coil readings
Last Post: Billy1200
0 Top end reassembly...what goes where!?!?!
0 3/4” Axle Drum Brake ??
0 UltraCool oil cooler safety concern
14 I just kind of stumbled in here... like 100 times.
0 Inherited Ironhead
Last Post: Akdawg
0 Noise and rod play
Last Post: Vic8028
warpusher, Terp84Alum, FiremistSLK (74), moony956 (72), E.H-57 (63), bplinson (56), fbroos73 (47), prefect (40), bamf_shadow (38), jakebuganski (38), Arwalkz007 (37), Fraser19 (31)
Old 10th October 2016
TrackNicholson's Avatar
TrackNicholson TrackNicholson is offline
Sportster/Buell Model: XL1200CX
Sportster/Buell Year: 2016
TrackNicholson is a name known to allTrackNicholson is a name known to allTrackNicholson is a name known to allTrackNicholson is a name known to allTrackNicholson is a name known to allTrackNicholson is a name known to allTrackNicholson is a name known to allTrackNicholson is a name known to allTrackNicholson is a name known to allTrackNicholson is a name known to allTrackNicholson is a name known to all
Default '16 Roadster | V&H Stage 1
Just a quick 3 pull reading session on a mobile dyno.
V&H V02, V&H Upsweep 2-into-1, V&H Fuelpak3
74whp & 72 lb.ft.
'16 Roadster | Vance & Hines Upsweep | V&H V02 | V&H Fuelpak3
