0 Valve Lengths?
0 Chinese S&S carbs
Last Post: 11B40
Last Post: JonesL
0 73 XLH Total Power Loss
Last Post: sleighcrane
0 Cleaning carbon build-up
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 What oils do you run in your ironhead
0 Lifters+w cams
0 HF bike lift
Last Post: salmanmr
Last Post: jharback
0 Chasing Down Leaks
Last Post: ericfreeman
0 Main shaft bearing preferences
Last Post: Heff
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
bore size, master cylinder, piston
Old 20th May 2019
Roane Roane is offline
Roane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to allRoane is a name known to all
Default what brake master cylinder can I use?
I posted this question in another thread about an electrical problem I am having but thought I should probably separate it as it is related to me but unrelated to you.
Any idea the bore size of this master cylinder (is OEM for my bike I think... 1977 sporty) but it’s running to dual calipers (no idea the number of pistons and there are no markings anywhere I can find stating bore size anywhere).
The calipers look like they might be V-Twin.
https://www.jpcycles.com/product/241...left-and-right
This is the pricey master I want to use, which comes in 9/16" or 11/16"
https://www.rolandsands.com/product/...r-mount/chrome
Here are the links to the pics from my bike.
http://xlforum.net/forums/attachment...5&d=1558298552
http://xlforum.net/forums/showthread...2072109&page=3
