0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Chinese S&S carbs
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
0 Gasket placement
Last Post: Billy1200
0 Top end failure
Last Post: Mission1
0 What a birthday I've had
0 Mystery transmission piece??
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 XR mutt race bike progress
Last Post: supermotolew
0 Info needed on mini sumps.
Last Post: mrmom9r
0 Don't Think I Ever Did This
Last Post: Veeflys
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sticky Ironhead trans
0 Inherited Ironhead
0 HF bike lift
Last Post: BigLerowski
0 Graduated to Ironhead
Last Post: jharback
  #71
Old 1st August 2013
NCWSporty's Avatar
NCWSporty NCWSporty is offline
Sportster/Buell Year: '13
NCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to beholdNCWSporty is a splendid one to behold
Here is my sheet. There will be a more comprehensive tune soon.
Not bad numbers but I think they can be bettered.
The dyno print out is askew a bit also...
A stock baseline pull is shown also, with SE intake, V & H slip-ons & xieds. My bike ran primo this way...
My bike has:
NRHS Stage I heads with bumped up compression due to milled head & thinner head gasket. Shorter pushrods to go with.
Andrews N4 cams
SE intake, soon to be replaced with a better flowing intake.
Patriot Defender, tuned with the butterfly about 30 degrees from full open.
PC-V, rpm's limited to 6200 at this point. More rpm's in the future.
Stock baseline
My Custom
Fire the motor, twist the throttle, life is good
Old 25th August 2013
NCWSporty's Avatar
Default New and Improved
After a fair amount of time tuning, Aaron at AWS pulled another ten horsepower out of my bike.
Just goes to show different dyno operators may be better than others.
And to take the time to find the power as Aaron did on my rather finicky bike.
The difference in hardware is a Air Hammer intake and a Power Vision vs the PCV I had previously.
Thank you Aaron. You know your craft.
Old 25th July 2014
terrya88's Avatar
terrya88 terrya88 is offline
Sportster/Buell Model: XL883C
terrya88 is on a distinguished roadterrya88 is on a distinguished roadterrya88 is on a distinguished road
2012 1200C
All stock except
Vance & Hines Shortshot
Vance & Hines VO2 Naked Air Cleaner
Guess my numbers aren't too bad.
Terry
2012 XL1200C
Old 30th September 2014
High Side High Side is offline
Sportster/Buell Model: Sportster XL1200C
Sportster/Buell Year: 2012
High Side is a splendid one to beholdHigh Side is a splendid one to beholdHigh Side is a splendid one to beholdHigh Side is a splendid one to beholdHigh Side is a splendid one to beholdHigh Side is a splendid one to beholdHigh Side is a splendid one to beholdHigh Side is a splendid one to beholdHigh Side is a splendid one to beholdHigh Side is a splendid one to beholdHigh Side is a splendid one to behold
2012 XL1200C
Vance and Hines Staggered Strait Shots with Quiet Baffles
HD SE Heavy Breather A/C
Rest of the bike is stock.
69 HP and 77 Ft Lbs of Torque. Tech said he had some pulls as high as 73 HP, but the average was 69 HP.
Old 12th April 2015
2012XL1200's Avatar
2012XL1200 2012XL1200 is offline
2012XL1200 is an unknown quantity at this point
Default 2012 XL1200CP Taxes
ENGINE: 2012 XL1200
AIR FILTER: Arlen Ness B/S Stage 1
EXHAUST: V&H Short Shots
OTHER: SERT
Bone stock other than listed above.
HP: 78 TQ: 77
Old 30th October 2015
cycowrencher's Avatar
2003 XLH 1200 82.45 HP / 76.23 LBFT TQ at D.A.S. Performance in Dracut MA
Untouched stock:
Heads (0.025 Gasket)
Pistons /Jugs (0.010 Gasket)
Intake manifold
N4 Camshafts
Patriot Exhaust
2 inch Hurricane Flow Center inlet A/C
Ultima Ignition Custom Curve
6900 RPM limiter.
2004 CV40 Carb:
200 main
45 slow
CVP N65C Needle 2 shims
CVP Accel Squirter
Sent from my LG-LS995 using Tapatalk
Old 4th November 2017
EL in NH's Avatar
EL in NH EL in NH is offline
Sportster/Buell Model: model 48
Other Motorcycle Model: FLHS
Other Motorcycle Year: 1991
EL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to behold
Peace
Old 1st December 2017
ApexRider's Avatar
ApexRider ApexRider is offline
Sportster/Buell Model: XL1200CX
Other Motorcycle Model: Honda VTR 1000 Super Hawk
Other Motorcycle Year: 1998
ApexRider is an unknown quantity at this point
my submission is thus: 2017 Roadster, Stock internals, SE stage 1 AC, Cobra El Diablo 2-1, PCV, tuned at Ray Price HD in Raleigh, NC
2017 XL1200CX Roadster: SE a/c, PCV, Cobra El Diablo, Le Pera Sorrento
Old 22nd November 2018
Folkie Folkie is offline
Just a reminder: posts with dyno charts only; no comments or chat here please. Other posts will be deleted. Comments and questions about the dyno charts posted here can be posted in a separate thread in the Dyno Charts And Results section. Thanks.
Old 27th April 2020
Fiachra's Avatar
Fiachra Fiachra is offline
Fiachra is an unknown quantity at this point
Default 2013 XL1200C Stage 1
ENGINE: 2013 XL1200C
LOWER END: Stock
CYLINDERS: Stock
PISTONS: Stock
HEADS: Stock
ROCKERS: Stock
PUSHRODS: Stock
LIFTERS: Stock
CAMS: Stock
CARBURATION: n/a
AIR FILTER: SE Heavy Breather
EXHAUST: Cobra Dragsters Full
IGNITION: Stock
COILS: Stock
CLUTCH: Stock
TRANSMISSION: Stock
OTHER MODS RELATED TO ENGINE: n/a
COMMENTS: None
