Last Post: mrmom9r
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: 4th of July
0 Can’t go over 70mph
Last Post: SLW210
0 TC88A Maps for 883 to 1275 Basic Converstion
0 Reflectors...Yeah, or Neh
0 Chinese S&S carbs
Last Post: T. Clark
0 Recent 1275 Dyno Tune
0 Hammer 560 VS 570 Felt differences?
0 2006 XL1200 OEM Battery Dimensions
0 Swingarm has a slight twist
0 Cycle Cover for Sportster
Last Post: FiftySixer
0 Minnesota denied federal aid
0 Mikuni Knock Off "REVEALED" !!!
0 Tappet blocks and tappets
0 Headwork
0 Air filter Q
0 1982 front master cylinder sight glass replacement
0 New Member
merc, schvamf (48), MikeLightnin, o2man98 (40), Toadz (32), WingNut15B (32)
adjustment, ironhead, pushrods, valves
  #31
Old 19th August 2011
bruley bruley is offline
Sportster/Buell Year: 1982
bruley is on a distinguished roadbruley is on a distinguished roadbruley is on a distinguished roadbruley is on a distinguished roadbruley is on a distinguished road
Checking the compression is a good idea......I would be willing to bet that if he checks compression cold, it will be in normal range. If he checks compression hot, it will have dropped significantly (because a valve is open). If that is the case........adjust pushrods with a cold engine and you will likely solve all your problems. If you have poor compression readings cold and hot, you have a valve problem or a ring problem. There is a sticky in the tech section to help determine which using a bleed down test.
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
I agree, but I guess if you don't have a baseline to check against, it would be futile. Maybe a good time to establish one if not already done.
There are lots of problems with the ignition and fuel system that can cause hard starting when the engine is hot. I would get a baseline on the compression and like bruley said, wait til the engine is stone cold, adjust the valves according to the manual and go from there.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
