0 What a birthday I've had
0 Tire pressure
0 Chinese S&S carbs
Last Post: sleighcrane
0 Adjustable main with mag
Last Post: davixlrtt
Last Post: mac93
0 Mounting seat with out frame tabs?
0 Cleaning carbon build-up
0 Changing Battery(with factory Alarm)
0 Gasket placement
Last Post: Billy1200
0 Top end failure
Last Post: Mission1
0 Mystery transmission piece??
0 Keihin Butterfly crack
Last Post: Tipofthelake
0 XR mutt race bike progress
Last Post: supermotolew
0 Info needed on mini sumps.
Last Post: mrmom9r
0 Don't Think I Ever Did This
Last Post: Veeflys
0 Hammer 1250 kit with fp3
Last Post: Pagey
0 Sticky Ironhead trans
0 Inherited Ironhead
0 HF bike lift
Last Post: BigLerowski
0 Graduated to Ironhead
Old 1st September 2016
MatHormell's Avatar
MatHormell MatHormell is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: Buell XB12R
Other Motorcycle Model: Yamaha
MatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond repute
Originally Posted by mac93 View Post
Nice dyno sheet mat. Got a couple questions hoping someone can chime in on. Not saying there's anything wrong with what you have just trying to learn. Why do you think there was clutch slip? We would get spikes in the torque early thinking that's what caused it. . Before a dyno session I would add static and weight and it seemed to stop that. I run a lock up. But not really sure if the extra weight is what helped. Also, our engines are really close builds , only difference I see is cams. I dynoed with a different exhaust but I have a patriot on it now. Would my torque curve be the same as yours? Don't care about the numbers just the shape of the curve. Thanks, Got some big races coming up and don't want to miss anything.
I felt it was slipping because of how fast it was turning up on the dyno.. Wasn't enough slip to register on the dyno except on one run and it had like a slope incline on the big end.. I strongly believe the exhaust determines your curve more than anything!
Sent from my SAMSUNG-SM-G935A using Tapatalk
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HAMMER PERFORMANCE Intake Manifold
HSR 48 Miunki
XR1200 Crank Conversion W/ Case Mod 34T
HAMMER PERFORMANCE Sledge+ Head Work
2.020" Intake and 1.630" Exhaust Valves
Conical Valve Springs
S&S Premium Lifters
HAMMER PERFORMANCE Billet Push Rod Bases
Barnett Clutch Hub With Scorpion Clutch
Dynatek 2000i
R&D MOTORSPORTS- TRANSMISSION WORK-REM ISF
WorldWideBearings
Patriot Defender Exhaust
MatHormell's Avatar
Also Mac I would think with you combinations your just higher compression really so I'd imagine we would have very similar curves with the same exhaust
