Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Intake and Exhaust > Paying Taxes
Paying Taxes Got questions, tips or advice???
0 Sportster Fork Upgrade
Last Post: Redbeard2
12 Crankcase breathing?
0 Do you use a bike cover?
Last Post: Old Rocker
0 Rear sets?
Last Post: bordens
Last Post: Vic8028
0 "S" model specific Q&A
0 Ground Up Beginner Build
Last Post: Paul.W
0 Turbo Iron 883
Last Post: Cj_
Last Post: PetesPonies
Last Post: Blackmagellan
0 Clutch springs
Last Post: BigMek
0 Coil polarity
Last Post: Bikeaholic
0 Info needed on mini sumps.
0 primary cover
Last Post: smoggy
Last Post: davesz1r
0 Chinese S&S carbs
0 oil transfer valve
0 Tappet blocks and tappets
PEISprotster (68), 2009XR (66), Briank (61), bbj6635 (59), Reddog225 (48), larre1973, Irondrake77 (41), picowatt (40), Jeffrey99 (39), namesnick (39)
advice, air cleaner
Old 19th August 2017
Nick Nick is offline
Sportster/Buell Model: Xl 883
Nick is an unknown quantity at this point
Default Advice on what to buy (Air Cleaner)
Hi everyone. I'm just a bit of a lurker and don't post too much but I'm finally stuck.
I'm looking for a heavy breather/high flow air filter for my bike, but I want to sue the same cover that I've got on it at the moment. Everywhere seems to be a new circle look. I'm not exactly sure what I need to buy to make my bike look the same but perform better
Just for reference, I've got an 02 883.
Thanks in advance boys and girls.
This is the filter cover that I'd like to keep
Glamazon Glamazon is offline
Sportster/Buell Model: xl883r sold
Sportster/Buell Year: 2014
K & N do a performance filter that fits in the stock cover. Pretty sure it's also a Screaming Eagle Stage 1 part (+$!). I'm using an S & S teardrop for performance, looks & comfort as I found the stock cover bulky & it pushed my leg out a bit too far
Bikeaholic Bikeaholic is offline
Sportster/Buell Model: xl1250
Bikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud of
Hi,
So that is the standard Air Cleaner. You can get K@N air filters that offer more flow etc. Just remove old one and replace. Still use same cover.
Perhaps can also modify the A/C to also allow more air flow to go with the K@N. That would be the cheapest way I believe. I have an S@S stealth circular breather ( complete unit )and i think the standard oval cover goes over it. Hence the stealth name. I just left mine without the cover.
Plenty of people on this forum have done numerous things with the Air Breather.
Give it some time and I am sure they will also reply. All the best.
Thanks for the responses already. When I spoke to the local dealer he said that I'd have to get the backplate re done to make the high flow filter worth it. Does the k&n one come with that or is it just a replacement for the element?m
Does the s@s stealth come with the he whole kit and kaboodle and then you can just slap the original cover on it. It's just I'm fairly happy with the cover and think the way it looks suits my bike
andy_t's Avatar
andy_t andy_t is offline
Sportster/Buell Year: 2016
andy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant future
The s&s comes with everything needed to install, and the stock cover bolts to that.
Andy
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Hammer Performance Air Hammer air cleaner.
Folkie
South East England Riders
Old 20th August 2017
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Model: Sportster Superlow 1250
hexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond repute
yep +1 on the Hammer air cleaner. I got one and will not run any thing else. And you can rout the breather fumes and oil away from your intake. That stuff builds up really quickly on the piston tops.
2014 Sportster Superlow, Hammer 1250, smash head work, 560 cams, S&S rockers and lifters. ported throttle body and intake,
Hammer crush air cleaner, Barnett clutch
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
Progressive suspension front & rear
sportytrace's Avatar
OzChick
Sportster/Buell Year: 08
+2 for the Hammer Performance Impact Air Hammer. Fits well with stock cover, though there'll be a little bit of the filter visible on your 2002 Sporty. Their backplate design will certainly improve air flow for you too.
Old 21st August 2017
Thanks heaps folks. My actually getting the hammer 1275 kit so the air cleaner will match it perfectly I'd say. I didn't realise they did one. Thanks a lot
