0 Reflectors...Yeah, or Neh
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: thefrenchowl
0 Emission hose loose
0 Can’t go over 70mph
0 fork oil
0 fuse block
0 Wet Sumping (No oil returning)
Last Post: FalcoFlash
0 Resto-Repair 84 ironhead
0 Air filter Q
Last Post: Billy1200
Last Post: maltesefalcon
Last Post: Akdawg
0 ultima install without VOES
Last Post: supermotolew
0 TC88A Maps for 883 to 1275 Basic Converstion
0 Chinese S&S carbs
Last Post: T. Clark
0 Recent 1275 Dyno Tune
0 Hammer 560 VS 570 Felt differences?
0 2006 XL1200 OEM Battery Dimensions
merc, schvamf (48), MikeLightnin, o2man98 (40), Toadz (32), WingNut15B (32)
horn, install, loud
Old 16th January 2009
FourCams's Avatar
FourCams FourCams is offline
Sportster/Buell Year: 1969
Sportster/Buell Year #2: 1972
Other Motorcycle Model: FXSTC
Other Motorcycle Year: 1996
FourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really nice
Originally Posted by russzx6 View Post
Remarkably similar to my diagram fourcams??. . ..I must not have been clear enough?
Originally Posted by Chaoszen View Post
So will 10 amp wire do me for the entire wire Job? Hell I don't even know what gauge wire to use.
Aparently not.
That's why I tried to simplify YOUR drawing and include wire gauges for Chaoszen that matched or exceded the current load.
I'm not tryin to step on yer toes there buddy... Really: I just figured; "yeh just a small wire and 10 amp fuse . .bugger all current draw from a pair of horns i think." was a bit vague and I wanted to simplify it a bit.. Also, the ground wire in the switch in your drawing is for an iluminated rocker switch. In the horn circuit it would be a direct short. I removed it from the drawing to eliminate blown fuses and confusion.
I'm just tryin to be helpful man... sorry.
♠ 1969 XLCH ♠ 1972 XLCH ♠ 1996 FXSTC ♠
Chaoszen's Avatar
Chaoszen Chaoszen is offline
Sportster/Buell Model: XL
Chaoszen is an unknown quantity at this point
Default Horns
It started me thinkin about it on the first diagram and then the lightbulb went off in my head with the second diagram. It must have been those HOOT HOOTs. Thanks for the diagrams.
Old 10th June 2013
zimbros12's Avatar
zimbros12 zimbros12 is offline
Sportster/Buell Model: XLH 1200 Hardtail
zimbros12 is just really nicezimbros12 is just really nicezimbros12 is just really nicezimbros12 is just really nicezimbros12 is just really nicezimbros12 is just really nicezimbros12 is just really nicezimbros12 is just really nicezimbros12 is just really nicezimbros12 is just really nicezimbros12 is just really nice
Originally Posted by FourCams View Post
I don't know if this will help or not...
The horns usually draw 3-5 amps (each) so a 15 Amp fuse would be suitable to replace the 20/25Amp fuse in Russ's drawing.
There are several other circuits in addition to the horn on the same 15 Amp accessory breaker in the 74 wiring diagram. The relay might not be necessary. It wouldn't hurt to use it though - sometimes those 15 amp breakers aren't quite 15 amps over time. The relay would eliminate any doubt.
It is an old thread but I would like to say that your Schematic Diagram is right on.PLUG and HONK HONK.Thanks
