0 XR mutt race bike progress
Last Post: Scott
0 Top end failure
Last Post: Tipofthelake
8 Inexplicable miss
Last Post: gwcrim
5 Eye Protection When Riding?
0 Ignition advice
Last Post: Rhode Warrior
0 1992 XL ignition explained
Last Post: Bwf347
Last Post: keithnh
0 New guy from IL
0 normal shifter shaft wobble
0 Front Brake Upgrade
Last Post: keithnh
0 Chinese S&S carbs
0 Info needed on mini sumps.
Last Post: Randy_rots
0 Coil readings
Last Post: Billy1200
0 Bandanas
Last Post: Padre
0 3/4” Axle Drum Brake ??
0 Inherited Ironhead
Last Post: Akdawg
0 Noise and rod play
Last Post: Vic8028
Old 26th May 2020
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
Hi FE,
Any G carb is not meant to run methanol... S&S told me so at the time I had mine as a gas carb on a 67 74ci CH...
But I'm stubborn and will do as I think fit so I moded it meself, quite involved and took some time.
One step was to get rid of the idle/mid range long jet that screws from the top and to put it all on the outside, that's all the clear nylon piping you can see on mine. This probably doubled the size of the emulsion tube...
Next was a new float chamber inlet valve, twice the diameter of the G one, so 4 times the area, plus 1/2" supply line and massive taps from Swagelok.
The carb would still starve a touch sometimes, so empty but moded S.U. float chamber was added on the side, it did help...
Bye for now, Gene...
Patrick
Flat Head Forever
Old 26th May 2020
11B40 11B40 is offline
Patrick, When Robert's bike was running a wet turbo he used an S&S GAL running on methanol. I don't think that much was done to it. On that first record run we ran, the float broke flooding the whole mess. This was at the turn for the return run. I put a float bowl and float from a spare GAL in the truck on for the return run and Robert did get the APS-AB-2000 record at 176. I'll ask him if there was anything done to it when I talk to him. Plenty of Fuel Sportsters ran GALs.
Old 26th May 2020
Well, 11B40,
there are some differences, otherwise why would S&S have bothered at the time with a completely different fuel version?
Patrick
Old 26th May 2020
Originally Posted by thefrenchowl View Post
Patrick
interesting handlebar lever on the bike in the picture.i don't recognize it though.
Old 26th May 2020
French bike called Durandal (the name of the magical/supposedly unbreakable sword owned by Roland, a nephew of the emperor Charlemagne. Circa 778 AD, Roland died in a Spanish ambush at the Pyrenees Roncevaux pass so he bears now that name, Roland de Roncevaux)
Pressed steel frame and forks, best models like this one fitted with Python 4 valves engines and 4 speeds foot change gearboxes from Rudge.
Made in Dijon where I used to live for a while...
Patrick
Old 27th May 2020
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Conversion for the Super B is easy and would most likely be my choice if i is to run on Methanol. B just needs blank jets drilled out and they have inters big enough to handle alcohol. The bowl needs to be modded to accept the big needle/seat but that's not hard to do. And I have a few spare alcohol needles and seats.
I was worried about the inter circuit which has stopped me so far from making the decision to try and run Meth in this engine.
Really I should look for an "F" carb if I want to do Meth or else just run the "B".
Old 6 Days Ago
Captain Johnny Captain Johnny is offline
Sportster/Buell Year: 1969
Other Motorcycle Model: Triumph Sprint 900
Other Motorcycle Year: 1998
Captain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to beholdCaptain Johnny is a splendid one to behold
Default S&S MGAL update
I have 100 miles on the '66 XLH/XLCH with the MGAL carb.
Settled on the .040" intermediate long tube (jet) and the .072" main jet. I have the mixture screw 2 turns out. I'm running the classic S&S teardrop with a new S&S air filter element. The bike starts easy, idles steady and runs real good. The Autolite AT42 plugs are burning fine.
Gonna change the oil today then put a couple more tanks of gas through her and hopefully the MPG should be somewhere around 40. If so I will declare victory.
Old 6 Days Ago
Blind Owl
Cap'N, how big is the engine ?
If I decide to run a G I am still not decided on the GBL or the MGAL
My thinking was the B version would be better for low to intermediate rpm's. I don't know the flow rates for the L Series carbs but just remember the A versions were used on the bigger engines and for things like Land Speed Racing where you really only need top end.
It's going on an 80 cube engine but I know the Super B flows well enough to handle that.
I don't know if the Super B flows better (or worse) than the L Series, but always assumed it was better.
Old 6 Days Ago
Stock 900 with .030" oversize pistons. Don't know much about these carbs but the A version is an 1 7/8" throat, same as the Super B. And the Super B that I run on My '69 XLCH (stock 900) is super smooth, runs great, starts easy and can get almost 50 mpg when not being flogged.
So with the B version of the L series at 1 3/4", The A, at 1 7/8" isn't too big for a 900 Sportster even though some claim it is. According to the S&S catalog I have the Super B is recommended for any H-D Big Twin or Sportster with any degree of mods including stock engines.
So the MGAL with the 1 7/8" throat should work on a 900 Sportster......and it does.
Old 6 Days Ago
Blind Owl
Aha ! I keep forgetting the GAL is only the same size as the Super B.
I would probably have to run the MGAL rather than the GBL.
I think the Methanol setup is going to be more trouble than it's worth so maybe I can stop procrastinating and just settle on the MGAL. All becomes easy then.
Or maybe The Super B with an Accelo bowl ?
