8 Inexplicable miss
Last Post: gwcrim
5 Eye Protection When Riding?
0 Ignition advice
Last Post: Rhode Warrior
0 1992 XL ignition explained
Last Post: Bwf347
Last Post: keithnh
0 Top end failure
Last Post: Mission1
0 New guy from IL
0 normal shifter shaft wobble
0 Front Brake Upgrade
Last Post: keithnh
0 Chinese S&S carbs
0 XR mutt race bike progress
0 Info needed on mini sumps.
Last Post: Randy_rots
0 Coil readings
Last Post: Billy1200
0 Bandanas
Last Post: Padre
0 3/4” Axle Drum Brake ??
0 Inherited Ironhead
Last Post: Akdawg
0 Noise and rod play
Last Post: Vic8028
Old 2 Weeks Ago
mvent mvent is offline
Sportster/Buell Year: 1976
Other Motorcycle Model: 120ci Fatboy
mvent is just really nicemvent is just really nicemvent is just really nicemvent is just really nicemvent is just really nicemvent is just really nicemvent is just really nicemvent is just really nicemvent is just really nicemvent is just really nicemvent is just really nice
Default Putting Mikuni back on
After having difficulty kick starting 76 XLCH with butterfly Keihin thinking I had static timed correctly I switched to VM38-9 after reading it was easiest for kick starting. Still hard starting. Put Keihin back on. After discussing with a friend he suggested holding point cam full advance and rotating plate until points just open and lock it down, worked great one or two kicks cold, hot-warm starts once I got technique down pretty good. Going to put Mikuni back on to see if there is less drama hot starting. Will report back.
Old 2 Weeks Ago
Whitewalls's Avatar
Sportster/Buell Year: 1971
Whitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant future
https://m.youtube.com/watch?v=mKVh4pbyh2A
Static time per this video. The VM38-9 is a 1-3 kick carb that doesn't require a technique other than choke when cold.
Old 2 Weeks Ago
mrmom9r's Avatar
mrmom9r mrmom9r is offline
The only Mikuni technique = do not open throttle while cold starting or the enrichener doesn't enrichen.
Old 2 Weeks Ago
And the idle mix screw works backwards.
Old 2 Weeks Ago
Mikuni is on using Branch backing plate with stock cover, air screw set at one turn out, idle set at 1k RPM ( after warm up ). Tried starting as recommended no prime kicks or throttle, enrichener lever down, no go. Kicked few more times no start. Kicked 3-4 times ignition off WOT, closed throttle, ignition on lever down one kick fired up, went for 15 mile ride, idles even, pulls well and definately smoother over 60 mph. Shut it down let sit for 20 minutes or so, tried just kicking no start, shut ignition off 2 kicks WOT, ignition on, no enrichener, one kick fired up. For some reason cold or hot it wants cylinders cleared out, I can live with that.
Old 2 Weeks Ago
Whitewalls's Avatar
Whenever I've had starting issues like you describe its because the points aren't right or crappy gas.
Old 2 Weeks Ago
Have 50/50 mix of unleaded 93 and Cam 2 leaded 110 octane in tank, points at .018 both lobes.
Old 2 Weeks Ago
doodah man's Avatar
timing? push rod adjustment? no intake air leaks?
I've come to the conclusion that even with petcock off, I believe fuel is getting into cylinders because of the lean angle requiring cylinders to be cleared out before starting. I let it run for a few minutes with petcock off before restarting and that seemed to work, fired up warm 1 kick.
doodah man's Avatar
Success!!
I usually have to open the throttle slide a little when doing the first start of the day, then as I ride along and the engine warms up I can turn the idle screw back out and reduce the rpms as the engine will be racing when I come to a stop.
