0 Hammer 1250
Last Post: Pagey
0 Injector connections
Last Post: Pagey
0 Clutch Spring plate poll
0 Sportster Fork Upgrade
Last Post: Randy_rots
0 Show me your non-stock breather systems
0 VIN ERROR on speedo/tach combo
Last Post: Steve1250
Last Post: Blackmagellan
0 Do you use a bike cover?
Last Post: rjg883c
0 "S" model specific Q&A
Last Post: Buellbomb
Last Post: LLOYD883
0 What's your road name? How did you get it.
0 Coil polarity
0 96 1200XL Bobber - Drain Oil
12 Crankcase breathing?
the brewster (75), irate (74), jomosie (71), Gulfstream (63), LordVngr (60), [loopy] (48), aci2sux (46), doc05 (43), TOMSuperlow (41), Crusin_w00kie (40), DFuller1980 (40), h2oburymatt (38), Ivan Iler (36)
Gold Member's Avatar
Sportster/Buell Year: 1972
Here's what I recommend. On the bottom trees, take out the bolts and put a bit of metal in the slots and run the bolt in from the back side to spread the tube holes open. Don't wedge screw drivers in there, that will wreck the paint and it's not necessary. The stock bolt might be too long so you'll have to get another one. A PO simply twisted my tubes down and out and left deep barber-pole gouges in the chrome, and I mean deep. The holes are full of paint globs that will gouge the chrome. Clean out the holes and the tubes will go in and out with impunity, no struggle.
Okay once you have the holes opened with the bolt through the backside, push the tubes down and out using a socket at the top. Tap the socket with a bit of wood. Use penetrating oil on the tube holes in the trees.
Just be careful and you can save your chrome. Just don't do what my PO did.
Stop by my build thread:
