0 73 XL 1000 Sportster - SOLENOID BYPASS
0 Can’t go over 70mph
0 theNeckerCube's Problems (Exhaust, Carb, … ?)
0 ultima install without VOES
0 Now running 3.40 factory gearing
Last Post: cliffm
0 Yearly Allotment of Miles
Last Post: Bigshankhank
0 Headwork
Last Post: ericfreeman
0 Cam needle bearings correct install
Last Post: mrmom9r
0 95 tank on a 94
Last Post: Nilzar
0 WTB NOKK needle...
Last Post: lespaul6
Last Post: FiftySixer
0 80 xl1000 oil not circulating?
Last Post: pucketprutectah
0 Oh these college kids
0 WTB: XR1200 Luggage Rack and Tailbag (OEM)
12 Crankcase breathing?
flattracker1 (79), al sena (70), SwissXL (56), greendarren7 (49), martian (45), thadf (44), NOGOOD1%€R (37)
Old 2 Weeks Ago
72ch 72ch is offline
Sportster/Buell Model: Xlch
Sportster/Buell Year: 1972
72ch is an unknown quantity at this point
Default New Guy Here - Handlebar Question
I’m new to this bike but have already received a ton of good info from this site, so thanks for sharing all your expertise. I’m hoping you guys will be able to come through for me here.
I’ve recently acquired a ‘72 xlch. The bike was in great mechanical condition when I got it but, unfortunately, was missing many of its original parts as it had been modified over the years. At this point, aside from the engine and frame pretty much everything else has been altered. So, in a quest to spend as much money as foolishly as possible I’ve decided to do my best to return it to stock condition.
I’ve sourced and rebuilt a 33.4mm front end. The last issue was locating a set of two piece buck horns. I finally found a good set of bars, clamp, and a spiral throttle kit. Now I’m trying to figure out the controls on the bars. The bars have holes for two switches on the left side and one on the right. From what I can tell the two on the left are for horn and hi-beam/low-beam. The hole on the right side is a complete mystery to me. I have a shop manual and checked the wiring diagram which, if I’m reading it correctly, shows a “directional signal switch”. I don’t believe that the ‘72 came with turn signals, so what the heck goes there?
Old 2 Weeks Ago
doodah man's Avatar
Kill switch.
LLOYD883's Avatar
LLOYD883 LLOYD883 is offline
Sportster/Buell Model: xl883c
LLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant futureLLOYD883 has a brilliant future
And maybe the starter button, if it has electric start.
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
