Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > Firebrand
2 Your daily tunes...
Last Post: RDHenley
0 Touring on a Hugger
Last Post: RDHenley
0 Changing engine oil
Last Post: vagrant318
0 spark plug wire ohms
Last Post: Kbetts
0 Finding an accessory power source
0 Figure Machine external breather
0 Head bolts and conversion
0 Rocker cover torx
Last Post: Bikeaholic
0 su carb question
0 Stretched Swingarm
Last Post: Racepres
0 DYNO TEST RESULTS: SE 58mm Throttle Body
0 LED headlight caused problems
Last Post: dayypete
0 Who has gone from Jackhammer 570s to Impact 560s?
Last Post: hexnut
0 Mid West Meet & Greet
Last Post: Bow only
Last Post: koolbreeze
0 Bigger rear Pulley
0 Swingarm??
Last Post: Racepres
0 my recent ebay purchase
0 derby cover adjustment spring broke
Last Post: burely
0 Plug for Siren
0 HD spares and parts availability
Last Post: doc martin
0 LIQUIMOLY oil additive whose using it?
0 Who Runs Turn Signals?
Last Post: Tincan
Mr.Gordon, rayzer13 (57), GrumpyCoyote (51), billet93 (47), beast1 (46), Barney_rubble23 (46), DDT (42), mgaworecki (41), superman5a (39), Phoenix81 (39)
Old 11th February 2017
Firebrand's Avatar
Firebrand Firebrand is offline
Sportster/Buell Year: 2014
Firebrand is a splendid one to beholdFirebrand is a splendid one to beholdFirebrand is a splendid one to beholdFirebrand is a splendid one to beholdFirebrand is a splendid one to beholdFirebrand is a splendid one to beholdFirebrand is a splendid one to beholdFirebrand is a splendid one to beholdFirebrand is a splendid one to beholdFirebrand is a splendid one to beholdFirebrand is a splendid one to behold
Default Skid Plates
OK, sure, as a rule the factory never intended you to ride your Harley on dirt. That’s probably why it didn’t come with a Skid Plate. But who plays by the rules anyways? Whether you’re building a Scrambler, Tracker or just want a little extra protection for the inevitable curb jump or wheelie in your future, Firebrand has built a Skid Plate especially for you.
Laser cut from 3/32” thick aluminum and hand finished for precise fitment, the Firebrand Skid Plate provides the most engine case and frame rail coverage, while blending perfectly to the contours of your bike. Available in brushed aluminum or black powder coat finishes, the Firebrand Skid Plate is hand crafted with pride in Anaheim, California by people who ride motorcycles.
www.firebrandmotorcycle.com
rocketmangb's Avatar
Thats a nice looking piece !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 12th February 2017
RollTide_ATX's Avatar
RollTide_ATX RollTide_ATX is offline
RollTide_ATX has much to be proud ofRollTide_ATX has much to be proud ofRollTide_ATX has much to be proud ofRollTide_ATX has much to be proud ofRollTide_ATX has much to be proud ofRollTide_ATX has much to be proud ofRollTide_ATX has much to be proud ofRollTide_ATX has much to be proud ofRollTide_ATX has much to be proud ofRollTide_ATX has much to be proud ofRollTide_ATX has much to be proud of
Very clean. Saw this flash across the advertisements at the top the other day
Side note:
I wish someone would design a chin spoiler that went a little farther under the frame, "Almost" sport bike style. Would look great on some of the cafe bikes IMHO
Brad Brad is offline
Sportster/Buell Year: None
Got a price? I can't find it on your website and a catalog search of 'skid' returns 0.
http://firebrandmotorcycle.com/sport...ack-2004-2016/
Thanks man!
Old 30th October 2017
lucifer_mr2 lucifer_mr2 is offline
Sportster/Buell Year: 2012
lucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant futurelucifer_mr2 has a brilliant future
Just bought one. Nice looking bit of kit. Put it on my 2012 48 this afternoon.
Had a slight problem with the rear right section. There was a interference problem with angled edge and the brake master bracket. Bit of work with the die grinder and file, and it fit up well.
Other than that it looks great, can barely see that it is there.
Firebrand's Avatar
Sorry you had to work on it to fit. They are laser cut so they should bolt right up. if you could take a photo of where the issue is, we would like to see it to make sure its not a production problem. You can email it to customerservice@firebrandmotorcycle.com
Thanks!
Old 31st October 2017
Just sent, but the photo wasn't great.
