2 My 1275 Hammer Conversion..
0 Changed gas cap and experienced problems
0 stress killer
0 HD spares and parts availability
Last Post: Bored now
0 su carb question
Last Post: Serious Blac
0 In tank fuel filter on 2004 xlc
0 Bike not started for 5 years
Last Post: connorneil13
0 Another clutch Question
0 tire changer
Last Post: Eric Von Zipper
2 Your daily tunes...
0 Too HOT to ride?
Last Post: PetesPonies
0 Rear Master Cylinder Rebuild or New?
0 Frame bracket
Last Post: Bwf347
0 Happy Birthday Mrs. Folkie.
1 Three Harley-Davidson Sportsters That Don’t Care What You Think
0 Spoke hub bearing assembly
Last Post: Jonv
0 my recent ebay purchase
Last Post: Moon Wolf
Last Post: Bikeaholic
0 Best Tuner options?
View Poll Results: What grade gasoline do you use?
Premium Gas 91+ octane 3,709 81.95%
Mid-Grade Gas 89-90 octane 311 6.87%
Regular 87 octane 383 8.46%
I mix it up, don't care, etc. 104 2.30%
Change based on the weather 19 0.42%
Voters: 4526. You may not vote on this poll
  #1791
Old 13th November 2019
I run premium. There's a Mobil gas station "mart" about a mile from my house with 91 octane (M+R/2) no ethanol. I've been seeing some detonation, the ECU (with Powervision) has the detection software but oddly doesn't have the software to pull timing. So, I've been tailoring my fuel and timing mapping around knock indications. I expect the detonation to go away when I get the top end off and tighten up the squish clearances.
I went thru the same process on my BT Evo. It also had .055" head gaskets as OE. Harley made a running change to .040" head gaskets to tighten the squish clearance to fix the detonation issues the earlier BT EVO's had. I did more, also shortening the cylinders. Here I am 30+ yrs later doing the same the same thing on my '17 Evo Sportster. My BT EVO was an '87.
The owner's manual says premium gas for the 1200 and regular for the 883 because of the compression ratio for each.
I usually run mid-grade 90 octane because that's the only octane for my non-ethanol gas available locally. While traveling away from the house, I can run 87 in my 2005 XL883 with no problem.
I'm not a "never ethanol" guy. I run 91 octane no ethanol because the station conveniently near my house sells it. Their (Mobil) premium was 93 octane with ethanol previously and I ran that. Same station where I usually fill my daily driver with "may contain up to 10% ethanol" regular.
If I knew that I could ride my motorcycle daily like I do my cars, I wouldn't sweat the 10% ethanol gas because I know it would turn-over quickly in my tank.
However, my daily schedule and the fluctuating weather keep me from riding it as much as I would like to and it may sit for weeks or months at a time. So I keep a 5-gallon can of non-ethanol in the garage to top it off with after each ride. I would rather have it sit completely full of non-ethanol, just in case.
I also turn off the Golan manual petcock about 100 yards from my house so the carb will run empty when I park it in the garage. Probably overkill, but it's easy to do and it gives me peace of mind.
That's edited but I hope not out of context. If you're not comfortable with the current ethanol added fuels that's your prerogative.
I traded in a 2002 Kawasaki Mean Streak (that I bought new in 2002) on my Sportster in Feb this year, 2019. It had 9.5:1 CR and ran on regular. It sat 17 winters, plus 2 summers I couldn't ride due to surgeries and chemo, with regular "with up to 10% ethanol" in its' (full) tank. When I traded it in it still had all its' original fuel system components, the tank had never been off to be cleaned, the fuel system (EFI) had never been apart. No problems, ever.
I could go on but that is typical of my experience with ethanol added fuels. Racing on 100% methanol (and setting up carbs and fuel systems to flow enough) is a more fun story.
jcn59 jcn59 is offline
Sportster/Buell Model: 1200
Sportster/Buell Model #2: 1200
Sportster/Buell Year #2: 1994
Other Motorcycle Model: Aspencade
Other Motorcycle Year: 1986
jcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond reputejcn59 has a reputation beyond repute
I find that if I use non-korn-likker gas in my bikes, boats, lawn mowers and atvs, that come spring, everything starts right up & runs fine with no curse words or other issues. (Northern WI) I haven't noticed any other advantage. I suppose that if I jacked up the timing I might need the premium gas, but I don't.
Gone but not forgotten: RD 350 Yam, Kaw 3 cyl. 500, Kaw 900 Z1, 750 Honda SS, etc.
TUCCI's Avatar
TUCCI TUCCI is offline
Sportster/Buell Year: 2016
TUCCI is an unknown quantity at this point
Originally Posted by maddog View Post
The results are in !!! 100% use high-test !
Yeah I do ....the manual calls for it.
Old 4 Days Ago
Hellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud of
The question I have is:
At the selectable pumps, how much of the last pumped gas comes out before what you selected comes out? If you are only putting in 2-3 gallons the difference can be significant.
And you are paying premium for that left over gas.
I've got a stock 02 883 and run 87 all the time. I haven't noticed any pinging or rattling but it does diesel a bit when it's hot. Running lean? (stock jetting, three turns out on screw)
Old 4 Days Ago
How long is the hose? (length)
What is the inside diameter of the hose? (diameter/2)
(diameter/2) X (diameter/2) X 3.14 (pi) X (length)
If you use inches for the sizes - cubic inches X 0.00433 gallon
A 5/8" ID hose at 72 inches long (6 feet)- would hold ~ one tenth of a gallon.
A 10 foot hose would hold about 1.5 tenths of a gallon.
One tenth of a gallon of 87 octane added to nine tenths of a gallon of 91 octane would give you a mixed octane of about 90.6
(if the premium is 93 you would have about 92.4 octane)
91 buying 2 gallons ~ 90.8 octane
91 buying 3 gallons ~ 90.86 octane
Around here premium is 60 cents more than regular, so the difference is about 6 cents
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 4 Days Ago
Kbetts's Avatar
Kbetts Kbetts is offline
Other Motorcycle Model: Suzuki DL650ADV
Kbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond repute
I think the 883 is specified to run on 87 Octane. The 1200's are the ones that are spec'd to run 91/93 Octane. I just did 80 miles and filled up with Premium. It cost me an extra $1.20 more than if I used 87 Octane.
Doing the math.
I ride about 3000 miles a year on my bike not including long trips.
3000mi/46mpg =65 gallons
If you figure Premium costs 30% more than regular....
$2.50 gal * 65 gallons = $163 for regular.
Adding 30% for Premium $163 * 1.3 = $212
That's $50 a year/$4 a month extra for Premium. I think I can afford it if I give up Snickerdoodles in my lunch box.
