0 Barnet clutch spring plate
Last Post: stikflote
0 What engine oil do you use?
Last Post: Yakcm2
0 Happy Birthday Mrs. Folkie.
Last Post: Yakcm2
0 Front brake calliper strange noise...
Last Post: orvitarius
0 Frame bracket
0 Best Tuner options?
0 Fuel tank urns
Last Post: ezmerf
0 Hi from Barcelona!
0 top end noise
Last Post: jacsul
0 How tricky is it to replace dipstick trim from oil tank?
6 SPORTY BOBBER PICTURES
Last Post: Bryan83taco
0 Poll: Hwy Pegs: fwd mount or crash bar mount?
Last Post: oupa
0 su carb question
Last Post: Serious Blac
0 Buell special
0 Clutch lever pull effort
Last Post: Centennial Sportster
0 Too HOT to ride?
Last Post: PetesPonies
Last Post: burely
0 Another clutch Question
Last Post: wrkdWS6
Old 10th December 2019
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to behold
Default Dynojet Target Tune and/or autotune with PV
I just finished installing the engine upgrade kit in my 2019 Iron 883 and will be reaching out to Hammer for a base tune soon. Having said that, I would like to know if I would really benefit from purchasing a Target Tune? If so, should I autotune with the PV first to get the low to mid range cruising dialed in and then swap out the narrowband o2 sensors for the TT? I have searched high and low for a TT for the 2019 Iron, but it seems that they only list them for up to 2018 Irons. Was there a change between the 2018 and 2019 Iron, or are they the same, as far as running TT with PV? Thanks
