0 Shifter shaft seal.
Last Post: vagrant318
0 high milage sportsters
0 A tale of two wheels
Last Post: Matt Black
0 su carb question
Last Post: Bryan83taco
0 Who Runs Turn Signals?
Last Post: Gpa
0 Trans corner fix
0 Too HOT to ride?
Last Post: Racepres
0 Frankenbrakes
Last Post: Segway
0 Swingarm bearings - boy I'm glad I looked at them
Last Post: 1Scooter
0 Bigger rear Pulley
0 wtb - swingarm pivot locknut
Last Post: jsandidge
0 Cough and sputter resolved
0 Modify my dyna 2ki ignition
0 Still having trouble starting the 61xlh
0 cleaning method for cases
0 photo size
Last Post: stikflote
0 Stock Shocks/Oil Pump
2 My 1275 Hammer Conversion..
0 TC88a DIY Power adapter ?
0 Tank Paint Ideas
0 Hello from Northern Alberta
0 Quick brake question...
Last Post: robbie202
stroker ace (80), beunme (60)
Old 8th December 2019
Bryan83taco Bryan83taco is offline
Sportster/Buell Model: Iron 1275
Sportster/Buell Year: 2012
Bryan83taco has much to be proud ofBryan83taco has much to be proud ofBryan83taco has much to be proud ofBryan83taco has much to be proud ofBryan83taco has much to be proud ofBryan83taco has much to be proud ofBryan83taco has much to be proud ofBryan83taco has much to be proud ofBryan83taco has much to be proud ofBryan83taco has much to be proud ofBryan83taco has much to be proud of
Default Getting Hammered
After putting this off for a long time, I’m finally doing my 883 to 1275 conversion. I’ll be going with Hammer Performance and will hopefully get close to 90+ HP.
I got the Energy one clutch and spring plate done today. Tomorrow begins the engine tear down and packing the heads up to ship them to Hammer for some head work.
While the heads are away I’ll get the Impact 560 cams installed, chop the cam cover, and install A Lowbrow Customs belt to chain conversion w/1200 gearing.
I’ve already got a powervision tuner, and I’ll be upgrading to the bronze oil pump drive shaft while I’m in there doing the cams.
Any other suggestions from the experts?
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
You have a service manual, right? Double check everything.
I definitely have a service manual. I wouldn’t dare tackle this job without one! I think the manual was one of the first things I bought for my bike when I first bought it.
andy_t's Avatar
andy_t andy_t is offline
Sportster/Buell Year: 2016
andy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant future
aren't the pulleys and belt the same between the 883 and 1200? I thought the gearing difference was the primary drive.
Andy
Old 9th December 2019
rocketmangb's Avatar
Need to check years
28 tooth for 883 29 tooth for 1200
primary is different front pulley for 1200 @38 and 883 @34
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Looks like 2010 is the last yr the 883 had the 28t sprocket.
Starting in 2011 both the 883 & 1200 get 29t.
I ordered this kit from LowBrow Customs
https://www.lowbrowcustoms.com/lowbr...t-2004-up.html
It’s for 2004+. The front sprocket and and rear pulley dictate gearing, 883 vs. 1200. Please correct me if I’m wrong.
Got the heads and jugs off today. I’ll get the heads shipped off to Hammer this week. Next weekend I plan on installing cams (Impact 560), the above belt to chain conversion kit, and preparing the cam cover for a chop.
Odd question but, what do you guys do with the 883 jugs and pistons? Trash?
Dazed & Confused
You're right but there's also the primary gearing, the crank and clutch "sprockets".
883's get 34t on the crank while 1200's have 38t.
Both have 57t on the clutch.
The 2006 saw some transmission changes as well
Ahhh I see, thanks for the correction. Do you see any issues with running a 1200 belt to chain conversion on an 883 primary? I’m really just looking to lower the RPMs for 70+ MPH interstate cruising.
