Last Post: spitfirechopper
0 2021 Harley-Davidson Bronx
0 '86 1100 basket build
Last Post: Onlybckroads
3 Wtb, Wts, Wtt, Wtg (Evos)
0 Stacking the Alto Carbonite clutch !
0 fork reflectors
0 su carb question
Last Post: trappnman
0 How much can I get for my sporty?
Last Post: IronheadPhil
Last Post: Kbetts
0 Quick brake question...
Last Post: tussuck
0 Plug for Siren
Last Post: brixtonanima
0 Where we are! Put yourself on the Map.
0 high milage sportsters
Last Post: TUCCI
2 My 1275 Hammer Conversion..
Last Post: Proteus
Last Post: tennmoto
0 Bigger rear Pulley
Last Post: oldboy
0 Modify my dyna 2ki ignition
Last Post: vagrant318
0 Trans corner fix
Last Post: Proteus
nailhead (78), Rooster (63), chidovampiro (61), daniel (58), evereyken (57), RogueXR9OO (57)
Old 16th December 2019
Nibelungen's Avatar
Sportster/Buell Model: xl883n Iron (2019 engine)
On my ride the Dart one is excellent
the air flow pass just above the helmet... at any speed...
but i have mids, a low handlebar, and i'm tall 175 cm...
on my previous ride i had a different flyscreen and at low speed the air flow smashed on the helmet's visor... i keep it anyway... since i had always the visor lowered to protect my eyes...
emancipate yourselves from mental slavery, none but ourselves can free our minds
Old 17th December 2019
wheelerd's Avatar
wheelerd wheelerd is offline
wheelerd is an unknown quantity at this point
Originally Posted by SLW210 View Post
That really depends on the person, the motorcycle and setup and the screen.
I run a detachable gauntlet fairing at times on the Sportster, no buffeting/turbulence at all on me and current setup. I think the small fairings my be better all around.
Like mentioned, may take the right fly screen and some or a lot of tweaking.
So are you riding with an open face helmet or . . . ?
2005 Sportster Custom -- Screamin' Eagle II pipes; Willie & Max bags
SLW210's Avatar
SLW210 SLW210 is offline
Sportster/Buell Model #2: FXLR Low Rider
Sportster/Buell Year #2: 2019
SLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond repute
I ride open face 1/2 helmet and full face, sometimes no helmet, with and without the fairing. The fairing makes a noticeable difference in wind to the chest at high speeds, I get 0 buffeting (after adjusting it a little). I am 5'9" tall with a 34" inseam, so I sit low in the saddle so to speak.
Like I stated, it is more about getting it set up for YOU to eliminate/reduce any buffeting, some things just may never work for you or require a lot of adjusting. I have never liked a full windshield, but then I never set one up for me, just riding one the way it was set.
I just lay on the tank at high speeds on non-faired bikes.
XL Ed's Avatar
XL Ed XL Ed is offline
XL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond repute
As said it's all about getting it setup for you. I find a minimum fairing good for me take the pressure off my chest and smoothing the airflow around my helmet. I run one of those cheap Chinese quarter fairings. Works for me. I know Paul has a strip of moulding around the top of his windshield which he says breaks up the wind and helps to reduce buffeting. I've seen others run with the extra wing attached as well which they swear by. I've never tried one of those.
Old 18th December 2019
Yep Ed, “micro swirl edging from Saeng. Makes about a 3-4” larger air pocket to what else you are running. Also have the “Laminar lip” on the Memphis Shades “Guantlet fairing” on Black Beauty.
wheelerd's Avatar
Yep Ed, “micro swirl edging from Saenz. Makes about a 3-4” larger air pocket to what else you are running. Also have the “Laminar lip” on the Memphis Shades “Guantlet fairing” on Black Beauty.
Yes, I've researched both of these. But I'm looking for a combination that is as minimal as possible (ie. just a flyscreen) that will work with my 3/4 helmet. The Saenz edge might look OK on a black flyscreen but I just can't get see it on a clear screen.
XL Ed's Avatar
Compromises everywhere my friend. Happens most often when function follows form.
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
The Dart Pirahna (without the OE duckbill and with modded brackets) on my XL1200C is minimal, actually works well, and looks like it belongs. Sometimes you get lucky...
wheelerd's Avatar
Thanks for all the helpful advice thus far. Just to reiterate my initial post:
- I'm interested in hearing about experiences with a flyscreen AND and open face helmets (with or without a faceshield) at highway speeds.
- I've read virtually every thread here dealing with every type of shield and also various types of helmets, so I have a pretty good sense of the lay of the land.
- My only riding experience over thousands of miles has been with an open face and a naked bike. But now I'm looking for a little bit of wind protection without compromising the lines of the bike and still wearing an open face.
So:
- I realize that the shield and the helmet are usually not mutually exclusive. That's why I'm interested in finding a combo that works.
- I realize too that what works for one person might not work for the next.
- I'm 5'9 with 30" inseam. I ride with mid-controls on a stock seat.
At the moment I'm leaning towards the National Flyscreen for a couple of reasons. It has the same dimensions as the Dart Piranha but comes in clear and is somewhat adjustable (up/down and tilt.) I also need to replace my helmet, hence the interest in getting the combo right.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Originally Posted by Tomcatt View Post
the Dart flyscreens on my 1200C and my R9T are considerably better than without.
It was the opposite for me. The Dart Flyscreen on my 1200CB was very unpleasant, even at 30 mph! Much worse than without a screen at, well, any speed really.
Folkie
South East England Riders
