0 new member
0 my only real beef with my 03 883
Last Post: robbie202
0 exhaust gaskets
0 Anyone know where I can get one of these mini fairings?
0 Folkies Loft 2.0 " the Ccat tails "
Last Post: fafcpa
0 Seized 1200SPORT Fork Cap
Last Post: T_worth
4 What will 10 cents buy?
0 Wheel weight.
Last Post: Serious Blac
0 It's Flame__'s Birthday!
0 Oil hungry Iron Heads
0 Intake manifold
0 "S" model specific Q&A
Last Post: vagrant318
0 $ cost to have bike assembled?
Last Post: Bob F
Last Post: spamer80
Last Post: Bob F
0 103” or 90”
Last Post: Bob F
0 Trans corner fix
0 Screamin Eagle Wiring
0 Mag wheel allen rotor bolt removal
View Poll Results: What grade gasoline do you use?
Premium Gas 91+ octane 3,709 81.95%
Mid-Grade Gas 89-90 octane 311 6.87%
Regular 87 octane 383 8.46%
I mix it up, don't care, etc. 104 2.30%
Change based on the weather 19 0.42%
Voters: 4526. You may not vote on this poll
  #1291
Old 3rd September 2013
wedge's Avatar
wedge wedge is offline
Originally Posted by Iceman62 View Post
One of the dealerships ~1-hr down the road sells high octane fuel...91, 95 & 100. I try to head that direction whenever possible. Usually get the 95, but might try the 100 in my Sporty-S to see if she'll fly...
That may be fine, but it will require a different tune to get the most out of it. Are you willing to retune the bike every time you try a different octane of fuel? If not, settle on one you like and stay with it.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Why would it require a different tune? There's no more energy in higher octane fuel, just more knock resistance.
Folkie
South East England Riders
wedge's Avatar
Basically, higher octane burns slower, so timing will not be optimum unless you advance it some.
Folkie's Avatar
Brass Nut
Certainly no performance to be gained by using it on a motor that doesn't need it.
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
Right, so if it doesn't need it, it doesn't burn it fully and therefore it leaves behind more carbon deposits.
Folkie's Avatar
Brass Nut
You've lost me there; could you explain that please?
Do you mean because it burns slower? It doesn't burn it all in the time it's got?
So, does this mean that higher Octane fuel actually produces less power? Poorer performance?
(Unless compression is high enough to need that slower burning, of course.)
Bone's Avatar
OK, so you NEED higher octane to prevent pre-ignition/detonation on motors that run hot enough, or have high enough compression, or timing advance that is far enough ahead of time that lower octane would ignite at the wrong point in the compression stroke and finish burning too soon wasting some of the power before the power stroke is finished.
Higher octane is more stable and as such you do things like increase compression and/or advance the timing more to get more power out of the burn.
HOWEVER if you don't have sufficient compression or timing advance to make sure you get the combustion event over in time you can wind up with either incomplete burn and more carbon deposits and/or burn that is still taking place in the exhaust - neither of which are beneficial.
It's a long taught principle that using TOO high an octane will lead to carbon deposits, which increases compression over time and can actually make a motor that did not need higher octane require it at a later time.
Bone's Avatar
Have I not posted this here before - good news report testing back-to-back regular vs. premium in a car not spec'd for premium and showing results - premium polluted more:
http://www.cbc.ca/marketplace/episod...mpfiction.html
Folkie's Avatar
Brass Nut
Thank you; that explains it very well.
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Still debating this..........
Stuff: YES
