0 su carb question
Last Post: Serious Blac
0 In tank fuel filter on 2004 xlc
0 Bike not started for 5 years
Last Post: connorneil13
0 Another clutch Question
0 tire changer
Last Post: Eric Von Zipper
2 Your daily tunes...
0 Too HOT to ride?
Last Post: PetesPonies
0 Rear Master Cylinder Rebuild or New?
0 Frame bracket
Last Post: Bwf347
0 Happy Birthday Mrs. Folkie.
0 Changed gas cap and experienced problems
Last Post: TUCCI
1 Three Harley-Davidson Sportsters That Don’t Care What You Think
0 Spoke hub bearing assembly
Last Post: Jonv
0 my recent ebay purchase
Last Post: Moon Wolf
Last Post: Bikeaholic
0 Best Tuner options?
0 top end noise
0 LED headlight caused problems
0 Barnet clutch spring plate
Last Post: dayypete
0 Hi from Barcelona!
Gold Member's Avatar
Sportster/Buell Year: 1972
Default engine stand/anti spatter gel or spray
I'm going to need to make an engine stand. My thoughts are to make the parts and bolt them to one of my crankcases and then weld. My concern is getting MIG spatter all over the aluminum case.
I just heard about anti spatter spray and gel. Would one of these products protect the aluminum?
Alternatively I could always surround the area with wet rags.
I have a buzz box and can "weld" but I'm not really a welder.
- Marcus Aurelius
doodah man's Avatar
Engine stand dimensions in this thread...
http://xlforum.net/forums/showthread.php?t=1863120
Nine mile skid on a ten mile ride, hot as a pistol but cool inside.
rocketnorton's Avatar
Sportster/Buell Year: 1970
Other Motorcycle Year: 80+
rocketnorton is an unknown quantity at this point
steel spatter wont stick to alum.
pete
Al melts at a much lower temp though. I'm thinking the spatter will be hot enough to leave craters or marks of some kind on it.
doodah man's Avatar
Battle scars!
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I already have a couple kicking around the workshop but I've been thinking about building another one.
A bit more versatile. Swivel and tilt.
when you're building the stand just tack weld it together.then remove the cases to finish weld.the anti-spatter wont hurt.
