0 EFI conversion on an '05 1200c??
Last Post: kdanie
Last Post: Traxx
0 Iron-shed
Last Post: LetsDoIt
Last Post: Traxx
Last Post: Yakcm2
0 Cleaning clutch
Last Post: tussuck
0 New to the Chopper Lyfe
Last Post: tussuck
0 Bleed air from the oil drain tube after an oil change?
Last Post: tussuck
2 My 1275 Hammer Conversion..
Last Post: Bryan83taco
Last Post: burely
0 Too HOT to ride?
0 Checking slow jet is correct size
0 New member
0 Accessory Fuse
0 Why? (Old Threads Show Up)
0 su carb question
0 Performance valves and springs
0 Wtb--1967--1972 xlh
0 Frame bracket
0 In case you have not seen Harley-Davidson's New Business Plan-
0 Clunking into 1st after Clutch is engaged and shifter is pressed
Last Post: DitchTBHSMM
0 *DK Custom - Limited Time Sweetheart Deals - Save 10% On Select Items*
0 C.O.B.B. CBD oil
Last Post: TUCCI
0 new to me 883
Last Post: robbie202
pwssr, petefwa, skeeter883 (68), roadogette (67), khaskins (62), iriegnome (55), sportster808 (52), ironheadmax (50), matt275 (45), DJb (44), HDFirefighter (38)
  #41
Old 30th June 2018
you're right.i have them,and all the hardware.probably next winter.i think i'm going into the kicker bushing next week i'm on vacation.i have some ideas to reuse my worn -57 steel kicker bushing with a later larger o.d. sleeve/spacer.probably start a new thread.
Old 30th June 2018
what springs did you end up using?
springs are Manley .490 lift.inner springs are wound in the opposite direction as the outer.collars are steel.
Old 4th July 2019
IMG_0092 by Bruce Stoudt, on Flickr here's a picture of my homemade rear shock spring compresser.i got these high road clearance shocks at Oley this April.i have better covers on my low road clearance shocks I have on the bike now,so i'll swap out the covers.
Old 29th November 2019
I got these high road clearance rear shocks at Oley in april. I had new covers on my low road clearance shocks that were on the bike so I swapped covers on them yesterday and installed them on the bike today.one thing that got my attention is the low shocks had only 1 spacer washer in them the f.s.m.says 3 are standard.the high shocks had 4.
Old 7th January 2020
Sportster/Buell Year: 1969
RicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of light
I replaced the braided steel oil lines I put on back in the '80's with oem style rubber hose. IMG_0053 (1) by Bruce Stoudt, on Flickr IMG_0066 by Bruce Stoudt, on Flickr a -52 oem brake rod to replace the chroIMG_0067 by Bruce Stoudt, on Flickrme one I put on in the '90's.parkerized. the reworkedIMG_0056 by Bruce Stoudt, on Flickrd XLR heads by mrmom9r. exhaust port. IMG_0059 by Bruce Stoudt, on Flickr intake port. IMG_0058 by Bruce Stoudt, on Flickr Kibblewhite -R valves 1.950 int. 1.750 ex. IMG_0057 by Bruce Stoudt, on Flickr IMG_0065 by Bruce Stoudt, on Flickr silver paint and stub fins.my 1960 XLCH has it's 900 heads back again.
Very nice. I hope to have mine as tight some day.
Old 5 Days Ago
my recent ebay purchase before photo ] and after photo this is the 1958-'63 double derby primary cover.it's easy to spot a double derby from a few feet away.they have spot welds visible around the raised circular area around the clutch drum where the 2 pieces were joined together.
Old 3 Days Ago
simonster123's Avatar
simonster123 simonster123 is offline
simonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nicesimonster123 is just really nice
Looking good! Did you end up leaving the inside bare metal, or did you paint there as well?
Old 2 Days Ago
thanks simon i'm glad you asked.there was some mild corrosion under the paint on the inside so I stripped the paint off there also.the more I looked at it the more I was convinced it would continue to spread contaminating my primary oil if I didn't seal it off from oxygen.so it got the rustoleum treatment also.inside and out.rustoleum primer and paint.
