0 high milage sportsters
Last Post: SLW210
0 Changing engine oil
0 What jets do you use?
0 HD spares and parts availability
Last Post: Bored now
0 Is static timing enough?
Last Post: ccmman
0 my recent ebay purchase
Last Post: Blowupster
0 Swingarm bearings - boy I'm glad I looked at them
0 Plug for Siren
Last Post: robbie202
0 Who has gone from Jackhammer 570s to Impact 560s?
Last Post: Bikeaholic
0 fork reflectors
Last Post: slojoe631
0 su carb question
0 cam lobes
Last Post: XL Ed
Last Post: sprink
0 Figure Machine external breather
Last Post: TUCCI
Last Post: dayypete
0 The huge difference 4 degrees of Advance makes ...NOT
0 Throw out Bearing
0 Touring on a Hugger
0 Battery cable length
41caninek1 (79), InkyDoggy (69), shepsvettes (67), outlw (48), outlaw05 (48), bklyngeezer (47), Skinn (46), theguy35 (41), IronHound (41), 2013iron883 (39), huge_midgit (33)
Old 1st March 2014
statenine's Avatar
statenine statenine is offline
Sportster/Buell Year: 1973
statenine is on a distinguished roadstatenine is on a distinguished roadstatenine is on a distinguished road
Default Tamer II installation help
Hey guys, I know this is a very simple and straightforward install, so pardon my ignorance, but I am a bit confused about the installation instructions in regards to the diagram in my service manual. My bike is a 1973 XLH
Tamer II Installation Instructions
1. Remove outer primary cover to expose clutch
2. Remove clutch pressure plate and spring using oem spring tool or
large gear puller to compress clutch spring
3. Remove clutch plug center of bearing end replace it with our clutch
plug
4. Main input gear in center of the clutch shell is to receive the
bushing, insert it so chamfer is toward you
5. Put some grease in the bushing
6. Re-install pressure plate and spring, tighten the 6 nuts
7. Install outer primary cover and on later models adjust the primary
chain
8. Adjust the clutch as described in the Harley manual
9. Add oil to primary.
For step #3, are they referring to part# 070308 in the below diagram? The diagram below calls it a thrust collar, and the install instructions call it a clutch plug, so I just wanted to be sure.
For step #4, is this bushing replacing another part (if so, which part#?), or is it something new I am just adding in the end of the main input gear?
Thanks!
Old 1st March 2014
CHOPTOP37 CHOPTOP37 is offline
Sportster/Buell Model: XLC
Sportster/Buell Year: 1972
CHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of light
you are correct at step 3, you are replacing the stockthrust collar with the tamer.
put the bushing into the end of the clutch gear..
check the tamer fit into the clutch gear/mainshaft first..ive seen a few with correct bush to begin with.
the point of the tamer if you look at it is to take place of the thrust collar while stabbing into the shaft/bushing so it supports the basket, yet can still travel in/out with the clutch.
i like them .
Old 1st March 2014
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
#50 gets a bushing.
Old 2nd March 2014
statenine's Avatar
thank you gents!
Old 6th March 2014
statenine's Avatar
Ok so I finally got around to doing this install today, but I can't get the bushing into the end of the clutch gear. It seems just barely to big to fit in. Am I supposed to tap it in with a hammer, or should it slide in easily?
Old 6th March 2014
4camroadster's Avatar
4camroadster 4camroadster is offline
Sportster/Buell Model #2: XLS roadster
Sportster/Buell Year #2: 1983
Other Motorcycle Model: Sportster XL
Other Motorcycle Year: 1979
4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough
Its a tight press fit. I put a dot of red bearing locker on before tapping it flush with the end of the shaft.
Old 6th March 2014
doodah man's Avatar
if you don't have access to a press, be sure to put something between the hammer and the bushing so you don't deform the edge of it. try freezing the bushing too, might help a little.
Old 6th March 2014
Pan55's Avatar
Pan55 Pan55 is offline
Sportster/Buell Year: 77
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 77
Other Motorcycle Model: 1978 FX Shovelhead
Pan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to behold
ok I guess Im confused about the clutch tamer..
I thought it was a simple replacement for the throwout bearing collar
Old 6th March 2014
doodah man's Avatar
doesn't it go in the throw out bearing and replace the thrust collar??
why would it go past the throwout bearing all the way into the clutch gear ?? ( the collar and bushing being replaced)
i'm curious about this, too. just going with the flow on the bushing install!
Old 6th March 2014
statenine's Avatar
supposedly it goes past the bearing and in to the clutch gear so that it can help support the basket to eliminate any unneeded movement, but still be able to move in and out with the clutch.
