Last Post: kdanie
Last Post: Traxx
0 Iron-shed
Last Post: LetsDoIt
Last Post: Traxx
Last Post: Yakcm2
0 Cleaning clutch
Last Post: tussuck
0 New to the Chopper Lyfe
Last Post: tussuck
Last Post: tussuck
2 My 1275 Hammer Conversion..
Last Post: Bryan83taco
Last Post: burely
0 Too HOT to ride?
0 New member
0 Accessory Fuse
0 Why? (Old Threads Show Up)
0 su carb question
0 Wtb--1967--1972 xlh
0 Frame bracket
Last Post: DitchTBHSMM
0 C.O.B.B. CBD oil
Last Post: TUCCI
0 new to me 883
Last Post: robbie202
Old 6th March 2014
tracbike's Avatar
tracbike tracbike is offline
Sportster/Buell Model #2: Sportster XLH
Sportster/Buell Year #2: 1977
Other Motorcycle Model: Trac Dynamics / Razor,
tracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the rough
I use one it works, (helps) used a bearing/bushing installer that I made in shop tapped in make sure it is straight ,.. simple.
found this (relevance is the "chamfer")
http://www.zodiac.nl/instructions/339091.pdf
Old 6th March 2014
statenine's Avatar
statenine statenine is offline
Sportster/Buell Year: 1973
statenine is on a distinguished roadstatenine is on a distinguished roadstatenine is on a distinguished road
hmm, the tamer I received does not have a chamfered edge on the bushing. both sides look identical.
Old 6th March 2014
tracbike's Avatar
that's fine....
Old 6th March 2014
Pan55's Avatar
Pan55 Pan55 is offline
Sportster/Buell Year: 77
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 77
Other Motorcycle Model: 1978 FX Shovelhead
Pan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to behold
I have one down in my shop, still in the package... I will have to look about the chamfered egde*...
this is an older one, not sure if there is a difference between this and the newest ones available.
Old 6th March 2014
doodah man's Avatar
usa-vs-china, perhaps?
ledgends now offers this part too, but doesn't show if it comes with a bushing or not.
http://www.ebay.com/itm/Harley-Sport...f505ca&vxp=mtr
Old 6th March 2014
4camroadster's Avatar
4camroadster 4camroadster is offline
Sportster/Buell Model #2: XLS roadster
Sportster/Buell Year #2: 1983
Other Motorcycle Model: Sportster XL
Other Motorcycle Year: 1979
4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough4camroadster is a jewel in the rough
I have the original Tamer in my 80 and 83 they both work and do what they are suppose to. I recently plcked a tamerII up at a swap meet still sealed in plastic for a 79 project I'm doing. After going threw two adjuster screws being stripped I pulled the cover to have a look, the recessed well in the thrust collar that the adj. screw rides in was a unfinished mess! It caused all kinds of havoc trying to adj. the clutch. Needless to say it now holds receipts on the bench. I have heard the original company has ceased production and the ones being sold are Taiwan copies. ,but I do have a nice paper weight!!!
Old 6th March 2014
Pan55's Avatar
the one I have, came from a buyout of parts that were all purchased in 1996 era..
I still need to go look to see if its a Tamer II or not...
Old 8th March 2014
statenine's Avatar
ok so I got the bushing in tonight, put everything back together and adjusted my clutch per the manual. Since it is so late I have not fired it up to test the clutch adjustment, but with a properly adjusted clutch should I be able to roll the bike easily in 1st gear with the clutch pulled in? Because I can't roll the thing at all
Old 5 Days Ago
I don't like a Tamer in an Ironhead, I feel it is a bandaid "fixing" a symptom not the problem and may actually cause the clutch to drag. If it rode in a bearing instead of a bushing that would be better, but it is still a bandaid. A Geedunk, like the sound of money tossed into a wishing well.
I have assembled many XL clutches without a Tamer and have had few if any troubles.
The biggest thing is to not use a single spring, the stock dual springs are best, they are counter wound and cancel the twisting imparted when they are compressed. The second is to update an older clutch to use the sleeves and use sleeves that have not been crushed with new nylocks every time. Tack welding all the studs to the rear plate helps as well.
