0 What jets do you use?
0 HD spares and parts availability
Last Post: Bored now
0 Changing engine oil
0 Is static timing enough?
Last Post: ccmman
0 my recent ebay purchase
Last Post: Blowupster
0 Swingarm bearings - boy I'm glad I looked at them
0 Plug for Siren
Last Post: robbie202
0 Who has gone from Jackhammer 570s to Impact 560s?
Last Post: Bikeaholic
0 fork reflectors
Last Post: slojoe631
0 su carb question
0 high milage sportsters
0 cam lobes
Last Post: XL Ed
Last Post: sprink
0 Figure Machine external breather
Last Post: TUCCI
Last Post: dayypete
0 The huge difference 4 degrees of Advance makes ...NOT
0 Throw out Bearing
0 Touring on a Hugger
0 Battery cable length
41caninek1 (79), InkyDoggy (69), shepsvettes (67), outlw (48), outlaw05 (48), bklyngeezer (47), Skinn (46), theguy35 (41), IronHound (41), 2013iron883 (39), huge_midgit (33)
Old 4th December 2019
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Model: ironhead sporty
Sportster/Buell Year: 79
mickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud ofmickey t has much to be proud of
Default Fact or fiction?
As I read up iron heads and learning more about them is it true that a stock 1968 Ironhead topped out at 118 miles an hour?
Sent from my SM-J260A using Tapatalk
come see/come saw
take print material with a grain of salt
i find the iron to be tempermental
some days a pigeon and some days a statue
the fastest the 1974ch has been is 133mph barring any restriction (aka, open road and time)
will it do 118, probably so, with consistency, probably not
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
My 1973 XLCH didn't.
steve lewis steve lewis is offline
Sportster/Buell Model: 1972 xlch
Sportster/Buell Year: 1972
steve lewis has a spectacular aura aboutsteve lewis has a spectacular aura aboutsteve lewis has a spectacular aura aboutsteve lewis has a spectacular aura aboutsteve lewis has a spectacular aura aboutsteve lewis has a spectacular aura aboutsteve lewis has a spectacular aura aboutsteve lewis has a spectacular aura aboutsteve lewis has a spectacular aura about
My 72 topped out at 107, fast as it would go.
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
I remember 100mph or so a few times on '73 xlh. She was near the end.
waiteitei's Avatar
waiteitei waiteitei is offline
Sportster/Buell Model: XLH - Rowe Frame
waiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of light
my 1980 xls was good for about 105-110
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
It's very hard to know the truth.
You cannot go by what the Speedo says. They aren't accurate.
Cycle world did a "shootout" around that time but the Sportster listed was a "cheater".
Apart from which you could never trust cycle mags at the time.
But you can always make one go that fast if you want to.
so what is the final ratio
i forgot to mention i was running a 22 instead of a 19.
man, some sad days there, had a friend with a yamaha twinjet 100 that would clock out at 120mph. talk about a lot of statues to #?!# on.
running "p's" and redline at 7500.
stikflote stikflote is offline
Sportster/Buell Model: sportster xlc
Sportster/Buell Model #2: xlh 1200 c
Sportster/Buell Year #2: 2005
Other Motorcycle Model: Triumph Kawasaki
Other Motorcycle Year: 2018
stikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud ofstikflote has much to be proud of
On my Triumph street Triple, at speeds around 75 80 mph it almost impossible to hang on, the wind blast is tremendous, the bike top speed is around 150 ,
so i would expect it to be even more on the harley at those speeds ,and it is, with wide bars ,andi dont think my Xl C will get any where near 118mph
I'm a little curious about some of the high numbers posted.
It takes some serious power to overcome the drag coefficient of a non-streamlined conventional bike chassis.
