Last Post: kdanie
Last Post: Traxx
0 Iron-shed
Last Post: LetsDoIt
Last Post: Traxx
Last Post: Yakcm2
0 Cleaning clutch
Last Post: tussuck
0 New to the Chopper Lyfe
Last Post: tussuck
Last Post: tussuck
2 My 1275 Hammer Conversion..
Last Post: Bryan83taco
Last Post: burely
0 Too HOT to ride?
0 New member
0 Accessory Fuse
0 Why? (Old Threads Show Up)
0 su carb question
0 Wtb--1967--1972 xlh
0 Frame bracket
Last Post: DitchTBHSMM
0 C.O.B.B. CBD oil
Last Post: TUCCI
0 new to me 883
Last Post: robbie202
  #231
ferretface's Avatar
ferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to allferretface is a name known to all
Originally Posted by Iron Mike View Post
Did you have gray hair at the age of 12? You seem to worry a bit.
Plan for the worst, hope for the best.
Just got a parcel from an eBay seller, American_Legend, a new 20T trans sprocket. Plastic wrap on it says "Dixie Distributing Company".
BTW: Just read DR DICK's thread, trans access door alignment, http://xlforum.net/forums/showthread.php?t=1392866 , and if I'm not mistaken, DR DICK is saying that the dowel pins are what regulate trapdoor alignment. And consequently the shaft placements. The four bolt holes location is more or less arbitrary (within limits).
So, to answer my own question in post #1 of this thread, it would be a good bet that the dowel pins and shafts location for the trapdoors would be interchangeable between similar years. Only the bolt holes might need enlarging.
