Last Post: kdanie
Last Post: Traxx
0 Iron-shed
Last Post: LetsDoIt
Last Post: Traxx
Last Post: Yakcm2
0 Cleaning clutch
Last Post: tussuck
0 New to the Chopper Lyfe
Last Post: tussuck
Last Post: tussuck
2 My 1275 Hammer Conversion..
Last Post: Bryan83taco
Last Post: burely
0 Too HOT to ride?
0 New member
0 Accessory Fuse
0 Why? (Old Threads Show Up)
0 su carb question
0 Wtb--1967--1972 xlh
0 Frame bracket
Last Post: DitchTBHSMM
0 C.O.B.B. CBD oil
Last Post: TUCCI
0 new to me 883
Last Post: robbie202
  #41
... upper tree center, see the bolt. that is the grd. i replaced mine with stainless stud and grd all wiring needed for the front.
This is exactly what I recall from my 1978. In case you are not familiar with the terminology, the upper tree is at the bottom of the pic
Serious Blac's Avatar
Serious Blac Serious Blac is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: Oh yeah!
Serious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud ofSerious Blac has much to be proud of
"Upper yoke" in proper English
The Devil is in the detail.
Hippysmack's Avatar
https://www.picclickimg.com/d/l400/p...riple-Tree.jpg
Thanks for that pic bustert.
Then the handlebar ground does just bypass the rubbers under the bars.
From this thread, it seems 'best practice' is to run a strap from the tree to the frame?
https://c8.alamy.com/comp/B4TPE5/wel...ast-B4TPE5.jpg
in slang, this is usually called a christmas tree.
