Last Post: kdanie
Last Post: Traxx
0 Iron-shed
Last Post: LetsDoIt
Last Post: Traxx
Last Post: Yakcm2
0 Cleaning clutch
Last Post: tussuck
0 New to the Chopper Lyfe
Last Post: tussuck
Last Post: tussuck
2 My 1275 Hammer Conversion..
Last Post: Bryan83taco
Last Post: burely
0 Too HOT to ride?
0 New member
0 Accessory Fuse
0 Why? (Old Threads Show Up)
0 su carb question
0 Wtb--1967--1972 xlh
0 Frame bracket
Last Post: DitchTBHSMM
0 C.O.B.B. CBD oil
Last Post: TUCCI
0 new to me 883
Last Post: robbie202
Old 5 Days Ago
Hennepinboy Hennepinboy is offline
Sportster/Buell Year: 1966
Other Motorcycle Model: Yamaha XJ650
Other Motorcycle Year: 1982
Hennepinboy is an unknown quantity at this point
'66 XLH, I attempted to cut a set of aftermarket drag pipe to work with HD 65230-65 mufflers. The fit was not good. I ended up purchase a NOS rear HD pipe and a good used front HD pipe. With the factory pipes everything lined up as it should.
Old 5 Days Ago
Originally Posted by TUCCI View Post
My Roadster came with Short Shots and the first thing I did to it was slid in some quiet baffles. I wouldn't mind em a bit quieter but it'll do. I wish the bike woulda come with the original mufflers, Icthink the Roadster stock pipes are cool looking.
"Sticking baffles inside drag pipes is like trying to fart around a cork!"
