0 su carb question
Last Post: Serious Blac
0 In tank fuel filter on 2004 xlc
Last Post: connorneil13
0 Another clutch Question
0 tire changer
Last Post: Eric Von Zipper
2 Your daily tunes...
0 Too HOT to ride?
Last Post: PetesPonies
0 Rear Master Cylinder Rebuild or New?
0 Frame bracket
Last Post: Bwf347
0 Happy Birthday Mrs. Folkie.
Last Post: TUCCI
1 Three Harley-Davidson Sportsters That Don’t Care What You Think
0 Spoke hub bearing assembly
Last Post: Jonv
0 my recent ebay purchase
Last Post: Moon Wolf
Last Post: Bikeaholic
0 Best Tuner options?
0 top end noise
0 LED headlight caused problems
0 Barnet clutch spring plate
Last Post: dayypete
0 Hi from Barcelona!
Gold Member's Avatar
Sportster/Buell Year: 1972
Gold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to behold
Default plunger seat springs question
My parts catalog tells me the plunger springs fit years 54-70, but my bike is a 1972 and has the plunger seat tubes.
I think I can safely assume the Colony repro springs will fit but I want to double check with the experts...
Curly: Hey Moe, I was thinking...
Moe: Well don't, you'll weaken the nation
"If you have the means, I highly recommend picking one up." - Ferris Bueller
"Put an end once and for all to this discussion of what a good person should be, and be one."
- Marcus Aurelius
FWIW, 9r's kit fits everything through 1972.
http://xlforum.net/forums/showthread.php?t=1585479
I'm no Luddite; I just hate the march of technology.
chilly chilly is offline
chilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to allchilly is a name known to all
On my 72 one of the down tubes had a smaller internal diam than the other ?, so I had to make smaller bushes to suit.
when i went to a solo, i made brackets that went on the strut fastener, this on a 74 ch.
mrmom9r's Avatar
mrmom9r mrmom9r is offline
1971 and 72 bikes may or may not accept a plunger style seat kit. After 1970 not all the seat base castings where machined for the bushings and some frames have thicker wall down tubes so the springs don't fit. Some even have one regular and one thick wall tube as stated above.
OEM and most repop springs are 13/16" O.D. ( .8125") The bushings are 1" O.D.
The springs in my kit are 3/4" which gives more clearance inside the tubes for rust, dents, etc. but they still don't fit the thick wall tube versions.
