0 Changing engine oil
0 What jets do you use?
0 HD spares and parts availability
Last Post: Bored now
0 Is static timing enough?
Last Post: ccmman
0 my recent ebay purchase
Last Post: Blowupster
0 Swingarm bearings - boy I'm glad I looked at them
0 Plug for Siren
Last Post: robbie202
0 Who has gone from Jackhammer 570s to Impact 560s?
Last Post: Bikeaholic
0 fork reflectors
Last Post: slojoe631
0 su carb question
0 high milage sportsters
0 cam lobes
Last Post: XL Ed
Last Post: sprink
0 Figure Machine external breather
Last Post: TUCCI
Last Post: dayypete
0 The huge difference 4 degrees of Advance makes ...NOT
0 Throw out Bearing
0 Touring on a Hugger
0 Battery cable length
41caninek1 (79), InkyDoggy (69), shepsvettes (67), outlw (48), outlaw05 (48), bklyngeezer (47), Skinn (46), theguy35 (41), IronHound (41), 2013iron883 (39), huge_midgit (33)
Old 2 Weeks Ago
Sportster/Buell Year: 1969
RicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of light
Default Mag wheel allen rotor bolt removal
Next to impossible! Aggravated to no end! Bending allen wrenches. Rounding out allen. Corrosion, Loctite whatever.
Rant complete.
What's the trick? Heat?
Old 2 Weeks Ago
harley506d's Avatar
Sportster/Buell Model: 1200c
I would guess some heat and an impact wrench.
Old 2 Weeks Ago
cazz1000 cazz1000 is offline
Sportster/Buell Model: xlx
I had to grind a slot in all,of mine for a flat head , then heat and a hand held impact and wacked it with a 2 pound sledge hammer,, pain in the azzz,,,
Old 2 Weeks Ago
They are on there with an excess of red LockTite
Old 2 Weeks Ago
You can say that again! It's not 2 or 3 it's all of them!
Thanks for the tip on grinding a slot for a flat head. I'll probably do that since the allen holes are all rounding. Glad I have new disc. I suppose new hardware, stainless allens would be in order.
Old 2 Weeks Ago
heat,a socket with an allen bit and an impact gun.if the allen holes are rounding a slot won't be better.
Old 2 Weeks Ago
a deep slot will ,,but u do get into the rotor,, and if u don,t have no other choice, and new rotors, what u gonna do,,,
Old 2 Weeks Ago
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
If the allen holes are rounding (sounds like it) AND you have access to a TIG machine, you might consider sacrificing some allen bits:
  • using your TIG, tack an allen bit to the bolt(s) in a couple of places
  • get some heat in there
  • use a socket & impact on the allen bit
But I would like to see a pic of exactly what you're working worth before I'd recommend doing the above. aka I suspect it's doable but I'd want to ensure one can get in there with a TIG torch without doing any other damage.
Old 2 Weeks Ago
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
High heat, oxy/acet or acet plumbers
Old 2 Weeks Ago
very good answer doc,,, but I don,t weld,, it makes sense,, ty,, never thought about it,,,
