0 Touring on a Hugger
Last Post: Kbetts
0 su carb question
Last Post: nychopper
0 Who Runs Turn Signals?
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: Yakcm2
0 Magneto base for 70 XLCH
Last Post: Pickss
2 My 1275 Hammer Conversion..
0 Too HOT to ride?
Last Post: Skeezix
0 Figure Machine external breather
0 Bigger rear Pulley
0 Trans corner fix
0 Krome Werks HP Plus slipons - Replacements ?
Last Post: burely
0 TC88a DIY Power adapter ?
0 high milage sportsters
0 Front brake calliper strange noise...
Last Post: TUCCI
Last Post: Clevspeed
0 How tricky is it to replace dipstick trim from oil tank?
Last Post: TUCCI
stroker ace (80), beunme (60)
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
All of the welding tips are good, but the OP has no welding capabilities.
Sportster/Buell Year: 1969
RicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of light
Where did you get that info? It is incorrect.
Apologies. That was someone else who chimed in.
Did you get them out??
No worries. No I put the two wheels on the back burner and went on with other task. I will be picking up a dozen nuts at Tractor Supply to weld onto the frozen allen heads.
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Bummer, I've had some like that.
One thing about use of an air gun, I get better results by using a low
torque setting and letting the gun 'hammer' the bolt for a while.
Too high torque and you snap the bit.
I also soak with PB-blaster (not WD-40) between heat cycles.
Nitro57xl Nitro57xl is offline
Nitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really niceNitro57xl is just really nice
I agree about the low torque! I said put some pressure on it, not try and twist it hard? This tool works much better than the impact driver most motorcycle guys are used to. The vibrations will break the bond holding the threads.
I really hate the Torx bolts used on new bikes , really easy to break the bits or twist the center out of the bolts. I wish the engineers that design this shit had to work on it!
Originally Posted by decman View Post
... I also soak with PB-blaster (not WD-40) between heat cycles.
Or maybe Fluid Film?
the yukon sizzler the yukon sizzler is offline
Sportster/Buell Year: 1979
Other Motorcycle Model: duo-glide
Other Motorcycle Year: '58
the yukon sizzler is an unknown quantity at this point
Had the same issue with the mags on my '81 XLS. Just snapped the bit off inside the head. Drilled a small hole on the outer edge of the tapered head then using a centre punch at an angle in the hole, knock the punch counter clockwise. The shocking effect works a treat, no welding reuired. Good luck.
Thats sounds like a pretty good idea.
