0 su carb question
Last Post: Serious Blac
0 In tank fuel filter on 2004 xlc
Last Post: connorneil13
0 Another clutch Question
0 tire changer
Last Post: Eric Von Zipper
2 Your daily tunes...
0 Too HOT to ride?
Last Post: PetesPonies
0 Rear Master Cylinder Rebuild or New?
0 Frame bracket
Last Post: Bwf347
0 Happy Birthday Mrs. Folkie.
Last Post: TUCCI
1 Three Harley-Davidson Sportsters That Don’t Care What You Think
0 Spoke hub bearing assembly
Last Post: Jonv
0 my recent ebay purchase
Last Post: Moon Wolf
Last Post: Bikeaholic
0 Best Tuner options?
0 top end noise
0 LED headlight caused problems
0 Barnet clutch spring plate
Last Post: dayypete
0 Hi from Barcelona!
Hooligan1%er Hooligan1%er is offline
Sportster/Buell Model: Iron head
Hooligan1%er is an unknown quantity at this point
Angry If it isn’t one thing it’s another ... ( starter now )
So even tho I never got to finish diagnosing the one cylinder firing issue , then the starter gives out . I but a brand new battery and this ....
In the 2nd video I’m cranking the bike over with the plugs out Of the holes .. sounds fine I think .
In the 1st video the plugs are in the holes and it sounds like the starter is dying . Won’t even turn the motor over .
We are only at 120 psi rear , 123 psi front . Shouldn’t be that difficult. Can anyone give me a little insight to WTF is happening here ?
Thank you .
https://www.dropbox.com/s/92je6iypvd...%2C%2012%2032% https://www.dropbox.com/s/26i5g51nuy...%20PM.mov?dl=0
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Model: Ducati
Other Motorcycle Year: 1974
oldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond repute
the link doesn't work for me
2006 1200c: Home Made a/c, Cycle Shack Slipons, Daytona TC88A w/JesterVII map (thank you, Rico), Street Trackers
sounds like not enough battery.
Put it on a tender overnight and load test tomorrow.
Try this link https://www.dropbox.com/s/92je6iypvdo92pp
that link is a sign up page
try jumping with a larger battery. when i added electric foot to my ch, i adapted a 400+cca lawn tractor battery, the hd-12 is marginal at a little over 200cca.
https://www.dropbox.com/s/92je6iypvd...%20PM.mov?dl=0
Kbetts's Avatar
Kbetts Kbetts is offline
Other Motorcycle Model: Suzuki DL650ADV
Kbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond reputeKbetts has a reputation beyond repute
What voltage is at the starter when the key is on? What voltage is at the starter at while cranking? Does the battery charge to 12.7 vts or above?
Check the battery leads. Sometimes they corrode inside.
Try turning the engine over by hand (rear wheel in air) to see if there is a mechanical drag.
Try pulling all the other fuses except the starter circuit to check for other issues causing problems.
That's all I can think of. Hope it helps. Welcome to the forum.
Keith
