Last Post: kdanie
Last Post: Traxx
0 Iron-shed
Last Post: LetsDoIt
Last Post: Traxx
Last Post: Yakcm2
0 Cleaning clutch
Last Post: tussuck
0 New to the Chopper Lyfe
Last Post: tussuck
Last Post: tussuck
2 My 1275 Hammer Conversion..
Last Post: Bryan83taco
Last Post: burely
0 Too HOT to ride?
0 New member
0 Accessory Fuse
0 Why? (Old Threads Show Up)
0 su carb question
0 Wtb--1967--1972 xlh
0 Frame bracket
Last Post: DitchTBHSMM
0 C.O.B.B. CBD oil
Last Post: TUCCI
0 new to me 883
Last Post: robbie202
Gold Member's Avatar
Sportster/Buell Year: 1972
Gold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to beholdGold Member is a splendid one to behold
Default engine stand/anti spatter gel or spray
I'm going to need to make an engine stand. My thoughts are to make the parts and bolt them to one of my crankcases and then weld. My concern is getting MIG spatter all over the aluminum case.
I just heard about anti spatter spray and gel. Would one of these products protect the aluminum?
Alternatively I could always surround the area with wet rags.
I have a buzz box and can "weld" but I'm not really a welder.
Curly: Hey Moe, I was thinking...
Moe: Well don't, you'll weaken the nation
"If you have the means, I highly recommend picking one up." - Ferris Bueller
"Put an end once and for all to this discussion of what a good person should be, and be one."
- Marcus Aurelius
doodah man's Avatar
Engine stand dimensions in this thread...
http://xlforum.net/forums/showthread.php?t=1863120
rocketnorton's Avatar
rocketnorton rocketnorton is offline
Sportster/Buell Year: 1970
Other Motorcycle Model: homebilt fxr
Other Motorcycle Year: 80+
rocketnorton is an unknown quantity at this point
steel spatter wont stick to alum.
pete
Al melts at a much lower temp though. I'm thinking the spatter will be hot enough to leave craters or marks of some kind on it.
doodah man's Avatar
Battle scars!
Old 6 Days Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I already have a couple kicking around the workshop but I've been thinking about building another one.
A bit more versatile. Swivel and tilt.
Old 6 Days Ago
when you're building the stand just tack weld it together.then remove the cases to finish weld.the anti-spatter wont hurt.
