Last Post: kdanie
Last Post: Traxx
0 Iron-shed
Last Post: LetsDoIt
Last Post: Traxx
Last Post: Yakcm2
0 Cleaning clutch
Last Post: tussuck
0 New to the Chopper Lyfe
Last Post: tussuck
Last Post: tussuck
2 My 1275 Hammer Conversion..
Last Post: Bryan83taco
Last Post: burely
0 Too HOT to ride?
0 New member
0 Accessory Fuse
0 Why? (Old Threads Show Up)
0 su carb question
0 Wtb--1967--1972 xlh
0 Frame bracket
Last Post: DitchTBHSMM
0 C.O.B.B. CBD oil
Last Post: TUCCI
0 new to me 883
Last Post: robbie202
Old 5 Days Ago
Yochstein's Avatar
Yochstein Yochstein is offline
Sportster/Buell Year: 1984
Yochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud of
Default Click, Click, Click of the relay
I read somewhere here on the forum a while back that a common fix for starter relay clicking is a good clean ground. I can start the bike when dead cold with no issues but occasionally after a good long ride, I'd stop to fuel up or park it for a bit and when I get back on, the relay clicks with no power to the solenoid to turn the bike over. I've replaced the relay 3 times so I don't feel like the relay is the issue. Am I thinking correctly that ground may be the issue? Anyone else have this issue? If I had a kick start, I'd be happy. The times this has happened away from home, I've had to bump start it which is fine but a little embarrassing.
Thanks,
Old 5 Days Ago
Yellowstone Kelly's Avatar
Ironhead Rider
Sportster/Buell Year: 1982
Sportster/Buell Year #2: 1969
Other Motorcycle Model: FLSTC
Other Motorcycle Year: 1996
Yellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant futureYellowstone Kelly has a brilliant future
How do you know that no power is getting to the solenoid? Do you have a voltmeter with you to know for sure that nothing's getting to it? I'd be checking the entire electrical path from starter relay to solenoid, including wiring, connectors, etc with a voltmeter while the problem is happening.
Electrical things can certainly have heat-related problems, you just have to find out if it's multiple bad starter relays, wiring, or a bad solenoid.
But none of those things should be getting hot just from riding. So I would lean more toward loose or poor connections in the wiring, myself.
Good luck in finding this, these intermittent problems can be a bear to find and fix.
Old 5 Days Ago
BigMek's Avatar
BigMek BigMek is offline
BigMek is a splendid one to beholdBigMek is a splendid one to beholdBigMek is a splendid one to beholdBigMek is a splendid one to beholdBigMek is a splendid one to beholdBigMek is a splendid one to beholdBigMek is a splendid one to beholdBigMek is a splendid one to beholdBigMek is a splendid one to beholdBigMek is a splendid one to beholdBigMek is a splendid one to behold
Probably not ground, since the starter and its solenoid ground through the starter body to the engine. I'd check the positive cable between battery and starter - I had a similar problem once because the cable rattled loose on the starter end.
Old 5 Days Ago
Yochstein's Avatar
Thanks for the tips. I will check all connections tomorrow. They’re calling for temps n the 50s Sunday. I’ll spend some time outside with her.
Old 5 Days Ago
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Ground, always the ground.
Old 4 Days Ago
sleighcrane's Avatar
sleighcrane sleighcrane is offline
Sportster/Buell Year: 1967
Other Motorcycle Model: FLHR
sleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to allsleighcrane is a name known to all
Starter relay well grounded?
Old 4 Days Ago
Yochstein's Avatar
That is the first thing I’m going to check.
Old 4 Days Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I would suspect the solenoid is going bad.
When you ride the bike and it gets hot and then you stop it for a short time you get what we refer to as "heat soak".
If you let it cool down long enough the relay will work again.
A bad ground is always a bad ground. Hot ore cold.
