Last Post: XL Ed
0 The Strociek Project
Last Post: spacecoast
10 1983 XR 1000 Starting Issues.
0 Video - Why Tire PSI Should Be Checked Often!
0 Tachometer Suggestions
Last Post: 1983Sporty
Last Post: Jeff
0 Early 1967 XLCH Tach
Last Post: Douglas
0 72 ih stroker advise needed
Last Post: rocketnorton
0 Ironhead engine problem?
Last Post: ZTatZAU
0 1968 ex barn dweller thread
0 Starter gaskets 74 XLH1000
0 Starting?
Last Post: Briank
Last Post: splineman
Last Post: Turbo Sporty 48
0 NOS cases
0 Video - Servicing the External Breather Catch Can
garryd (73), Chooch (70), kicker (64), Calgaich (61), skinnyboy (59), RogerB, Tonyb65 (56), sunkenloot (46), scoobs48, zman69 (40)
jets, jetting, needle, shim, shimming
Old 18th May 2012
seanchrist seanchrist is offline
Sportster/Buell Model: 1200 Sportster Low
seanchrist is an unknown quantity at this point
Default Shimming a Needle
My '06 Sporty seems to be running a little weak in the mid-range area, although it's fine at idle and wide open. I think I'm running a bit lean in the mids, but not sure. I'm wondering what a "normal" amount of shimming the needle is. To preface, I'm still somewhat of a newbie, but I'm not afraid to dig-in and get dirty.
Here's the set-up:
'06 Sportster 1200 low.
Samson Exhaust Straight Shots with 1/4 baffles, so 2" openings
Arlen Ness Big Sucker Stage II Intake
CV Carb w/ Main Jet: 200 & Slow Jet: 50
CV Performance Velocity Needle w/3 small brass shims
Mixture ~2 3/4 turns
Suggestions?
Old 18th May 2012
Don Burton's Avatar
Compared to your enormous 200 main jet and 50 slow jet your needle might be leaner but................! You might want to ask Ken at CVP if he thinks your CVP needle should be shimmed. I know that he tries to get them close enough so that they don't need it as his needles aren't restricted by the EPA. One thing is for sure. You don't want to be running on the taper of the needle at cruise. Anyhow, I have to wonder how you ended up with such huge jets?
Old 18th May 2012
Default Jets
I think I'm going to go back to a 48 slow jet, but previously, I had a 185 main jet that would sometimes cause my engine to cut-out if I gunned it going up hills (even with a full tank of gas). The 200 seems to have solved that, but I could swap that out for a 195 possibly. I should have the bike put on a dyna, but I don't have $300 bucks to have someone else tune it for me.
Old 18th May 2012
Bruce's Avatar
Bruce Bruce is offline
Old Fart M/C Club
Sportster/Buell Model: 883/NRHS 1250 custom
Bruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant future
Yes the jets are looking on the large size (might try a 180 and a 45 or 48 slow jet) for you engine combination. Engine could be running rich in the mid rang causing your problems. Also your exhaust might be causing a little reversion in the midrange. What do your plugs look like?
Ride safe!
Member of "The Cell #2"
Old 18th May 2012
Don Burton's Avatar
With the jets that you are running, I suspect that you're rich all the way around. If your engine is cutting out when you "gun" it then it runs fine after a brief period, a lean main jet isn't the likely problem. You have some other issues which might include the accelerator pump, needle and/or your exhausts. I would lean this carb back out with stock main and slow jetting then tune one circuit at a time. You did say that you had baffles in your exhaust, is that correct? If not, fix that first. The Mikuni web site has a Tuning Manual for their HSR 42 carburetor which gives some great on the road exercises that show you how to test your main jet for proper size. The guy that wrote it (Joe Minton) knows more about H-D carburetors (including Keihin CVs) than anyone else I know. You can't just look at your plugs. If you want to check your plugs you have to do so systematically while cutting the ignition off at different throttle settings like steady cruise, after a mile or so, and again at WOT. There are plenty of threads that here that will help you with that.
Old 18th May 2012
With the stock slow jet, it was 'farting' really bad during deceleration, and the 48 helped that immensely. Before I put the shims on the needle, it was cutting in-and-out during regular cruising, and the shims corrected that, though still leaving it kind of weak. I'll test the accelerator pump and see how it acts.
Old 18th May 2012
Don Burton's Avatar
Do you have baffles in your exhaust? Poor baffling can cause popping on decel, poor slow speed performance and poor performance when whacking the throttle open. Did you go straight from a 42 to a 48 slow jet or did you try a 45 first? If your bike is running lean during regular steady cruising you likely need a thinner needle in the straight portion. If shims are making a difference in this area, that means that you are cruising on the taper which isn't a good thing and will kill your gas mileage. What kind of gas mileage are you getting now?
Old 18th May 2012
These are the baffles in it: http://www.samsonusa.com/A-116.html They take the 2 1/4" pipe down to 2". The carb originally had a 45 slow jet in it which is why I went to a 48. How/where do I get a thinner needle?
Thanks for your help.
Old 19th May 2012
Don Burton's Avatar
Those straight through two inch ID baffles are causing some of your problems. A better baffle would be one that has a diverter in it. I'd put some better baffles in there and put your 45 slow jet and stock 180 main jet back in there and see how it runs at slow and moderate throttle settings. Ken hasn't provided the measurements of his CVP needles son I don't know what would be a thinner needle on the straight portion. The N65C Keihin needle is the thinnest needle in that area that I know of and it is likely thinner than your current needle but I don't know about your current needle for sure. H-D can't get the N65C from Keihin anymore. I happen to have a new one that I used for brief testing. How is your current gas mileage?
Old 19th May 2012
Current gas mileage is suffering for sure. Not sure exactly what it is, but it ain't good. How small of an exit diameter should I be shooting for? I was really hoping to get some better horsepower than a stock set-up.
