0 71 XLH Value?
Last Post: fafcpa
0 Allegheny National Park III
0 Oil coming out of top of cam cover
0 1960 XLH Stroker – a 13 year journey
0 72 ih stroker advise needed
0 ‘T’ cams, anyone familiar?
0 Evo sportster Ignition Modules
Last Post: Stojan85
0 Buell interview.
0 Sportster Tracker Wheel and Tire Questions
0 sportster revival
Last Post: The Doctor71
Last Post: jeffro57
0 No start after ultima ignition, thoughts?
Last Post: 83XLX
0 60’s XLCH front tyre
Last Post: 83XLX
0 Tuning a keihin butterfly
Last Post: 83XLX
0 '74 Front Brake Caliper leaking
Last Post: dtwaddell42
Mr. Lynn (75), dentat2 (51), OWNED13 (48), knolan.smith (43), Malicious44 (36)
carb adjustment, cv40, jet, needle
Old 29th May 2016
night-train night-train is offline
Sportster/Buell Model: modded XL883/1250
Sportster/Buell Year: 97
Other Motorcycle Model: FLHTCU
Other Motorcycle Year: 2008
night-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to beholdnight-train is a splendid one to behold
Default Changing Needle without removing carb?
I have a 97 sporty w/cv40 and tried to change the needle,but found the cap blocked by the throttle cable brackets upper tab.
I was tempted to cut it off, but figured to ask the collective.
How do you change the needle without removing the carb?
Getting really tired of pulling everything apart to screw with jets or needles. Made a great tool though
Old 29th May 2016
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
You have to loosen the throttle cable bracket to do it, but you can get the top off the carb without removing the carb. You can drop the float bowl and remove and replace jets without removing the carb too.
If you replace the screws with allen heads, they're a lot easier to remove and replace. Speed screws are handy for the float bowl. Yost make some nice ones. Or they did, when I had a carby; don't now if they still do.
Folkie
South East England Riders
Old 29th May 2016
bite the bullet, taint that hard. inventive but be careful as the torque is not inline posing a stripped head situation. snake on a plane? they do make a changeable bit screw driver with a cable shank.
Old 29th May 2016
I'll quit being lazy and just pull it apart again tomorrow. Almost perfect..Almost.
Old 29th May 2016
Rv7garage's Avatar
Rv7garage Rv7garage is offline
Sportster/Buell Model: 883R
Rv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond reputeRv7garage has a reputation beyond repute
Lol- good man
Old 29th May 2016
Goat's Avatar
Goat Goat is offline
Sportster/Buell Model: 1200c
Sportster/Buell Model #2: Xl1200C
Goat has a brilliant futureGoat has a brilliant futureGoat has a brilliant futureGoat has a brilliant futureGoat has a brilliant futureGoat has a brilliant futureGoat has a brilliant futureGoat has a brilliant futureGoat has a brilliant futureGoat has a brilliant futureGoat has a brilliant future
Might be easier to remove the tank.
Old 29th May 2016
Folkie's Avatar
Brass Nut
If you're contemplating removing the tank, you might as well remove the carb and be done with it.
Old 29th May 2016
John Harper's Avatar
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
Also, those screw heads are not Phillips, they are JIS (Japanese Industrial Standard) so be careful not to "cam out" those screw heads. A JIS #2 works perfect. I got one off Ebay for only a few dollars.
John
Old 29th May 2016
Pulled the carb this morning, ended up rejetting it instead of playing with needles. Running a 48 / 190 and 1.5 out. Bike is pulling even better than before. The 2K~3,5k hunting is gone as well.
The lean showed on throttle , and on the dyno run, but the motor was not running hot.
Going to check the plugs later when it's cooler out. Probably going to schedule a dyno session in the next week or so.
Need to see where my fuel economy is with the new jetting...
Anyone know where to get those clear plastic washers that come with the head vent/carb support kit?? Was thinking of using annealed brass if the pastic ones aren't readily available.
Old 29th May 2016
John
John, a good point! I found filing the tip off an non-JIS philips head allows it to sit in the JIS-screw properly, no camming.
