0 My Experience With Phat Performance
Last Post: Skuzeee
Last Post: jammantoo
0 Timing issue
Last Post: shovithead
0 Galled front piston
Last Post: vagrant318
0 Hydraulic conversion for wet clutch
5 1979 Sportster XLS Problems
Last Post: Thoroy
0 Can’t get upper triple tree removed. Advice?
Last Post: speedfoos
0 Bitwell races a 883 Sportster in the mexican 1000
Last Post: hexnut
0 carb pop on acceleration from stop
0 K&N or UNI Foam
0 Sportster security help
Last Post: Robtwowheels
0 Fixing a loose mirror
Last Post: sltm1
Last Post: LLOYD883
Last Post: Jowniofownio
Last Post: myrl883
0 Royal Enfield Bullet C5 Military
0 Need a source for Ironhead shocks
0 JACKHAMMER 570 Cams!
Last Post: Turbo Sporty 48
0 Brake cable on 72 xlch forward controls
0 attn DR DICK
Last Post: stray
Last Post: mac93
0 Oil pump working, no oil to rockers
Last Post: spacecoast
0 my '82 XLS Roadster project
0 1973 Ironhead Sportster rear shocks
Last Post: Iron John
sflier, dubi1946, unclesumo (61), 81ironsporty (59), cheyenne71597 (58), akk (58), MDRide, JohnK (54), 86stang (53), Dusty1985 (33), evokid8 (27)
Old 2nd January 2016
slcharger's Avatar
slcharger slcharger is offline
Sportster/Buell Year: 2014
Other Motorcycle Model: Triumph Thunderbird 1700
Other Motorcycle Year: 2010
slcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud of
Default The most cool part ?
If you had to choose the one aftermarket part that adds the most coolness to a Sportster, what would it be ?
Post your opinion + a picture.
slcharger's Avatar
Okay, let me start the show.
In my opinion the open belt drive is the part / accessory that add the most coolness to the bike.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Worn tyres, miles on the odo, and stories to tell.
Or: any part you put on your bike for any reason other than to make it look 'cool'.
Folkie
South East England Riders
jackddg22 jackddg22 is offline
Sportster/Buell Model: Hammer 1250
Other Motorcycle Model: 2015 Low Rider
jackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nice
1250 kit, good pipes, Power Vision, better suspension anything to make it run better.
Jack
rejeanprimeau's Avatar
Jack
Me too I like enlarged jugs.
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Rather bump the cubic inches up 1250 kit fix the shit ass braking system with Brembos and put miles on the odo than worry about over priced eye candy of open primary's on Sportsters ($2500)..
slcharger's Avatar
The worn tires I get, so the miles on the odo, but besides a lot of riding and joy, where is the cool part ? You want to wear it down to become some kind of rat rod ?
But anyway, answer accepted.
jzink0883's Avatar
jzink0883 jzink0883 is offline
Sportster/Buell Model: XL1200CP
Sportster/Buell Model #2: XLH1200 (traded in)
Sportster/Buell Year #2: 1998
jzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond repute
Smile
+1 The "cool parts" on my CP are the ones that help me ride longer and harder.
jzink0883, '15 XL1200CP, it ain't butt jewelry, it's a ride
slcharger's Avatar
The 48 cc, you don't see. Put on a sticker and people may know. How much added power or torque are in those 48 cc anyway ?
My guess is that through conventional tuning you can achieve the same and properly a lot more. Cams, working intake, exhaust, EFI retune, etc.
Regarding the cost of the open belt drive. When you are talking big boy´s toy, if you want it, you buy it. Taste is different, thank god for that, else there where no variety.
Now brakes, is that really an issue ?
These are not exactly race bikes, more like cruising. If you want to race or have a more sporty bike, you would properly have bought one of them ricecookers in the first place. BUT big brakes looks COOL.
ReddTigger's Avatar
Your guess is way off base..
performance engines are about combinations.. and the proper combinations to create the end result..
the additional 48cc or 4% increase is drastic when the end results are looked at.. which you will not get without the 4% increase in displacement.
now if you just add the 1250 kit to the same cams, etc, then you're not going to see the drastic results,, but if you properly apply the criteria to maximize performance then the 1200 can by no means achieve what is available to the 1250..
it's been shown to have engines over 120hp with 1250cc..
it's been difficult to get a 1200 over 100hp..
States I've Ridden in
71.3 hp 70.8 tq
