0 Sportster Fork Upgrade
Last Post: indianajames
0 Do you use a bike cover?
Last Post: rjg883c
0 "S" model specific Q&A
Last Post: Buellbomb
0 Adjusting Drive Belt While On A Lift
Last Post: LLOYD883
0 What's your road name? How did you get it.
Last Post: ronccc
0 Coil polarity
Last Post: Randy_rots
0 96 1200XL Bobber - Drain Oil
12 Crankcase breathing?
0 VIN ERROR on speedo/tach combo
0 Range With EFI 3.3 Gal Tank
Last Post: corndog76
0 oil transfer valve
0 New shocks on and old frame?
0 Chinese S&S carbs
Last Post: PetesPonies
the brewster (75), irate (74), jomosie (71), Gulfstream (63), LordVngr (60), [loopy] (48), aci2sux (46), doc05 (43), TOMSuperlow (41), Crusin_w00kie (40), DFuller1980 (40), h2oburymatt (38), Ivan Iler (36)
Old 3rd June 2020
MkC MkC is offline
Sportster/Buell Year: 1986
Other Motorcycle Model: Triumph
Other Motorcycle Year: 2002
MkC is an unknown quantity at this point
I've owned the bike since last July and between doing some mods right after I first got it and this most recent tear-down I've put right around 1,000 miles on it. It's possible there was oil leaking out of the trans vent but to be honest I never knew there even was a trans vent until I tore it down a couple of months ago. I changed the engine oil and it made me wonder why the oil looked black after a couple hundred miles. More than I would have thought but this is my first H-D so there's a lot that I don't know about how this is supposed to be. It also seems strange that when I drained the primary it wasn't overfull. My oil tank level stayed within the expected range on the dipstick. PO replaced the clutch fiber and steel plates just before I bought it, along with the starter, but he wouldn't have to pull the crank sprocket for that. Maybe he did and thats when the crank seal went missing, but I doubt I'll ever know.
