Keep & Kill
....1
8th December 2022
Posts: 587 Sportster/Buell Model: XLH 883 Sportster/Buell Year: 1995 Other Motorcycle Model: Honda CM450 Other Motorcycle Year: 1982
Jiffy stand spring
I think my spring may be a little weak. It doesn't snap into the parked position all that well. I'm not really trusting it, so I got a new one. How in the heck does one go about replacing it? All I have is a scissor jack that will totally be in the way. At least I have a front wheel chock and a home made block to keep the bike up straight on wheels without the stand.
I'm apprehensive about removing the old one, since I wouldn't be able to ride (or at least park) until I can get the new one on. Such a small thing that could render the bike dead in the water.
Anyone have any advice?
1995 XLH 883 Sportster Hugger
8th December 2022
Posts: 541 Sportster/Buell Model: XL 1200 S....X Sportster/Buell Year: 1999 Sportster/Buell Model #2: XR-1000 RX Sportster/Buell Year #2: 83 Other Motorcycle Model: SOLD - RZV500R/R1 hybrid Other Motorcycle Year: 1984
if you replace the spring its a good idea to replace the bushing as well... I just leaned the bike against the garage in gear put the stand up and took the bolt out... then there is no pressure on anything...
replace bushing and hook up spring then put bolt back in... check for normal operation...
i also put a dab of water proof grease on the bolt and bushing prior to assembly...
1999 XL 1200 Sport RX, SE 7500 ignition, SE air filter, DynoJet, K&N, Cone Engineering 2:1 pipe, Storz Steering damper, with 2012 XR1200X perf forks, 3.5 x18" wheels front and rear, Galfer stainless lines, XR1200 4 piston front calipers, 18" Dunlop D404 130/70 and Dunlop trailmax mission 140/80-18 rear XR1200X perf shocks, 19/48 530 chain conversion, Dart Flyscreen, Antigravity LiFePO4 battery
8th December 2022
I don't see a bushing in the parts manual for mine.
8th December 2022
Posts: 2,640 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2009 Sportster/Buell Model #2: XL1200L Sportster/Buell Year #2: 2009
I agree with the way 84 said, but put the pin in from the top. If the bushings do fail, & they will eventually, the pin won't drop out & lose the entire kickstand.
8th December 2022
What bushings are we speaking of? I don't see any on my 95 XLR.
8th December 2022
Posts: 9,690 Sportster/Buell Model: Sportster 883►1200 Sportster/Buell Year: 1994
8th December 2022
First sentence is "The 1998 model year was the first for using the kickstand bushings"
8th December 2022
Posts: 7,236 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
Make sure you hook up the spring first then install the pin, bolt or what ever you gona uses.
84rzv is correct about it, forget about all the penny trick, grounded screw driver or spring extender.
If you holes are elongated, just drill and install Chevy door's pin bushing; lot cheaper than H-D ones..
8th December 2022
Posts: 596 Sportster/Buell Model: XL1200T Sportster/Buell Year: 2017
The pictures in Sportsterpedia seem to show a stand that is completely devoid of any grease. It is any wonder those bushes wear out.
My nearly 6 year old has seen plenty of grease and no wear on the bushes.
The holes on my bike are elongated as the stand pivots around a triangle welded to the frame. It is part of the locking mechanism so the stand won't move with the weight of the bike on it.
Anyway as to this thread. Put the spring on and then you can locate the stand and lever into the down position and put the pin in.
8th December 2022
Posts: 3,041 Sportster/Buell Model: xlch Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLCH IR EFI Sportster/Buell Year #2: 1971 Other Motorcycle Model: BMW K1200RS Other Motorcycle Year: 2001
Lean it against a wall on the right side. Fix your kickstand.
Hybrid Mode
