Last Post: bagster guy
Last Post: wachuko
0 Need a rear fender
Last Post: 1skullster1
0 1999 S upgrades
0 It's been a great Ride!
0 Fried Engine?
0 Saturday Sportster Season 2
Last Post: Captain Johnny
0 Starting my project soon.
Last Post: ankered
0 Fiber Washer on Idler Gear
Last Post: DirtyHarry68
Last Post: Jtl2
Last Post: joe s
0 Bad Speedometer or Bad VSS?
Last Post: cookiemech
0 a man walks into a bar
0 My off-road build
Last Post: 84rzv500r
Old 5th December 2022
NP72Iron NP72Iron is offline
Sportster/Buell Year: 1972
NP72Iron has much to be proud ofNP72Iron has much to be proud ofNP72Iron has much to be proud ofNP72Iron has much to be proud ofNP72Iron has much to be proud ofNP72Iron has much to be proud ofNP72Iron has much to be proud ofNP72Iron has much to be proud ofNP72Iron has much to be proud ofNP72Iron has much to be proud ofNP72Iron has much to be proud of
Default ‘72 IH…early or late ‘72?
Hey all,
Working on building up the tranny on my ‘72 XLCH and when looking for the countershaft low gear bushing, the parts catalog lists 2, one for 54-early 72 and one for late 72 on.
How do I know if mine is an early or late 72 model?
#42 in the photo.
both have the same id
the diff is in length
35787-52 is 5/8
35787-72 is 1/2
Thanks for your reply [mention]bustert [/mention]. I don’t have one to measure for my current motor, so I don’t know which length I need.
In another thread you say that you don't have a c shaft 1st gear and don't know if it should have a speedometer gear attached to it.
Does your '72 right side countershaft boss look like the pics in post 1 here:
http://xlforum.net/forums/showpost.p...70&postcount=1
Or the pics at post 6 here? (probably not)
http://xlforum.net/forums/showthread.php?t=1257259
Chances are better than good that your '72 came with the trans driven speedo gear. If your case looks like the early one, then it did, and you have a choice. You can run the gear with the attached speedo drive or run a later gear without the speedo drive gear and no speedometer.
As to the bushings. Early gear use 35787-52. Late gear use 35787-72
rocketnorton's Avatar
rocketnorton rocketnorton is offline
Other Motorcycle Model: homebilt fxr
Other Motorcycle Year: 80+
rocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant futurerocketnorton has a brilliant future
i have a 1cs gear w/speedo gear, if ya want/need
cant see where you are
it's new a/m
im not using speedo drive in mine
if youre not gonna either, id suggest a reinforcing ring on cs bearing boss
also have used drive and new cable
pete
Looks to be the second one, right?
Sportster/Buell Year #2: '03
nope.the early one with a reinforcing ring rocketnorton mentioned.kind of looks like the r/s case broke before the ring was installed?
Well you sure can learn alot from a picture. And now you know what gear you need. Brucstoudt is right. Your case came with a speedometer drive gear and the boss that holds the bearing cracked and has been repaired.
This means you can't use the speedo drive gear. You need the later C shaft 1st gear #35760-73. It should come with the bushing installed.
The OEM mainshaft bearing race has been replaced. That's not a bad thing. Just saying.
Old 6th December 2022
Thanks for all the replies guys. You all are what makes this forum so great!
DR DICK DR DICK is offline
see #45 in your pic.
on the gear there is a recess that washer fits into.
depth of that recess is appx 1/16" for the early gear. uses the -52 bush. uses one of #45 washer.
depth of recess is appx 1/8" for late gear. uses the -72 bush. if you have this gear you use two #45 washer stacked up.
