Last Post: fafcpa
0 Fiber Washer on Idler Gear
0 Saturday Sportster Season 2
0 Bad Speedometer or Bad VSS?
Last Post: cookiemech
0 a man walks into a bar
0 My off-road build
Last Post: 84rzv500r
0 It's been a great Ride!
Last Post: denguy
0 Starting my project soon.
0 Fried Engine?
Last Post: Jtl2
0 Allegheny 2023
0 What am I doing wrong?!
Last Post: NP72Iron
0 Conversion Kit Choices
Last Post: bagster guy
0 Vintage Sportster seat?
Last Post: rocketnorton
RLAnderson (62), boomer (57), ESCOBAR (51), davenjeip (50), BLOODYKNUCKLES (47), Shudabenz (44), Sporre96, 071200low (39)
Old 8th December 2022
RandallM's Avatar
RandallM RandallM is offline
Other Motorcycle Model: Honda CM450
Other Motorcycle Year: 1982
RandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond reputeRandallM has a reputation beyond repute
Default Jiffy stand spring
I think my spring may be a little weak. It doesn't snap into the parked position all that well. I'm not really trusting it, so I got a new one. How in the heck does one go about replacing it? All I have is a scissor jack that will totally be in the way. At least I have a front wheel chock and a home made block to keep the bike up straight on wheels without the stand.
I'm apprehensive about removing the old one, since I wouldn't be able to ride (or at least park) until I can get the new one on. Such a small thing that could render the bike dead in the water.
Anyone have any advice?
1995 XLH 883 Sportster Hugger
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XL 1200 S....X
Sportster/Buell Model #2: XR-1000 RX
Sportster/Buell Year #2: 83
Other Motorcycle Model: SOLD - RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute
if you replace the spring its a good idea to replace the bushing as well... I just leaned the bike against the garage in gear put the stand up and took the bolt out... then there is no pressure on anything...
replace bushing and hook up spring then put bolt back in... check for normal operation...
i also put a dab of water proof grease on the bolt and bushing prior to assembly...
1999 XL 1200 Sport RX, SE 7500 ignition, SE air filter, DynoJet, K&N, Cone Engineering 2:1 pipe, Storz Steering damper, with 2012 XR1200X perf forks, 3.5 x18" wheels front and rear, Galfer stainless lines, XR1200 4 piston front calipers, 18" Dunlop D404 130/70 and Dunlop trailmax mission 140/80-18 rear XR1200X perf shocks, 19/48 530 chain conversion, Dart Flyscreen, Antigravity LiFePO4 battery
1983 XR-1000S to XR-1000RX Project Build Thread
RandallM's Avatar
I don't see a bushing in the parts manual for mine.
BKB's Avatar
BKB BKB is offline
I agree with the way 84 said, but put the pin in from the top. If the bushings do fail, & they will eventually, the pin won't drop out & lose the entire kickstand.
RandallM's Avatar
What bushings are we speaking of? I don't see any on my 95 XLR.
I know it's only 5 years old, but the Sporsterpedia has a wealth of knowledge collected there...
http://sportsterpedia.com/doku.php/techtalk:evo:body05
For Sportster Tech Info:
Ride On The Sportsterpedia - A Toll-Free XLForum Information Highway!
RandallM's Avatar
First sentence is "The 1998 model year was the first for using the kickstand bushings"
rejeanprimeau's Avatar
Make sure you hook up the spring first then install the pin, bolt or what ever you gona uses.
84rzv is correct about it, forget about all the penny trick, grounded screw driver or spring extender.
If you holes are elongated, just drill and install Chevy door's pin bushing; lot cheaper than H-D ones..
Andy56 Andy56 is offline
Andy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond repute
The pictures in Sportsterpedia seem to show a stand that is completely devoid of any grease. It is any wonder those bushes wear out.
My nearly 6 year old has seen plenty of grease and no wear on the bushes.
The holes on my bike are elongated as the stand pivots around a triangle welded to the frame. It is part of the locking mechanism so the stand won't move with the weight of the bike on it.
Anyway as to this thread. Put the spring on and then you can locate the stand and lever into the down position and put the pin in.
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Lean it against a wall on the right side. Fix your kickstand.
